Drives: Daihatsu Sirion 1.0 Join Date: Aug 2011
Hello guys, this is my 1st post on yarisworld
![]() The car is cheap Toyota : Daihatsu Sirion 2005, 1.0 1kr-fe, manual transmission, mileage 61,000 km. The problem is it consumes almost 8l/100km of gas (30 mpg), normal consumption should be 5 to 6l/100km. Symptoms: * long term fuel trim = -20..-30% on idle which isn't normal *abnormally black spark plugs (can attach photos, all 3 of them black equally) * the software reads no diagnostic trouble codes. I use Chinese elm327 Blutetooth + laptop. * both oxygen sensors seem ok _____________ 1. idle, warm: http://s30.postimg.org/9n6n2cq3h/02a_idle.jpg ![]() 2. car stopped, engine warm: ![]() 3. as above: ![]() 4. driving, engine warm: ![]() ______ Any suggestions? I'm thinking of MAP sensor, crankshaft, camshaft position sensors ![]() Will appreciate any help ![]() BR, Z. |
Hello,
The car is cheap Toyota : Daihatsu Sirion 2005, 1.0 1kr-fe, manual transmission, mileage 61,000 km. The problem is it consumes almost 8l/100km. Symptoms: long term fuel trim = -20..-30% on idle which isn't normal abnormally black spark plugs (all 3 of them) the software reads no diagnostic trouble codes both oxygen sensors seem ok The engine starts and works (idle, driving) normally. _____________ 1. idle, warm: http://s30.postimg.org/9n6n2cq3h/02a_idle.jpg ![]() 2. car stopped, engine warm: ![]() 3. as above: ![]() 4. driving, engine warm: ![]() ______ Will appreciate any help. BR, Z. |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
Sounds like it runs too rich.
I would check vacuum leaks, exhaust leaks, clean/replace MAF sensor. Pozdrowienia. |
What's the highest temp that the coolant gets to? 65*C ? If it is, then that's too cool.
![]() Drives: Yaris Verso 1.3 2000 automatic Join Date: Nov 2015
Did you get to the bottom of your problem?
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 02:35 PM |
| higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 07:17 PM |
| High compression engine | flow-vitz | General Yaris / Vitz Discussion | 1 | 11-15-2006 01:03 PM |
