Old 03-17-2016, 10:57 PM   #1
jorwex
Drives: Yaris
Replacement key for fob?
All,
I have a 2007 yaris sedan, purchased in the USA, with no immobilizer. Recently the metal key portion of my key fob broke off. The keyless entry portion of the fob is still intact and functional.
The sticker on the back of the fob has worn away, and I don't have the instruction manual anymore.
Two questions:
  1. Is it possible to replace only the metal key portion of the fob? If so, then I can simply get it cut and install it into the otherwise functional fob.
  2. From reading posts here, I understand that my car may only respond to one of the two FCC IDs that represent the 2007 key fobs without immobilizers (MOZB41TG and MOZB21RG?). Is there any other way to determine which replacement fob model is the correct one for my car, other than the sticker that has worn away and the car's instruction manual?
Thanks
jorwex is offline   Reply With Quote
Old 03-18-2016, 06:04 AM   #2
You can just replace the metal portion of the key.
For the correct key for your car, matching against the VIN is the best method. If you PM me your VIN I can look it up.
Old 03-18-2016, 06:57 AM   #3
jorwex
Drives: Yaris
PM'd. Thanks CTScott!
Replacement key for 2015 Yaris OGHUGO Third Gen Yaris General Discussion 14 08-09-2017 08:16 PM
Yaris 2007 (UK bought) Key Fob replacement sdfsdfsd General Yaris / Vitz Discussion 4 01-25-2016 05:44 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Replacement key with key fob modmonster Third Gen Yaris General Discussion 0 06-09-2014 05:24 PM
Replacement key / keyless entry mcduck DIY / Maintenance / Service 4 08-30-2010 06:52 PM
