Old 11-06-2018, 11:09 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Post Mil-Spec Engine Harness
I've had plans to have a RyWire style harness for a long time, but no one wants to build one for any of us without a 2JZ...
My solution = build one myself.
I had a spare 2ZR harness laying around that came with my engine from the junkyard, but it was damaged in the accident.
Step 1 - I stripped it down, labeled it all, and formed a plan of how to route it cleaner.
ArmstrongRacing is offline   Reply With Quote
Old 11-06-2018, 11:26 PM   #2
ArmstrongRacing
Data doesn't lie
Step 2
The routing plan.
Now, of course, I will need to have sub-sections branching out from the main loom. I'll try to keep it super clean along the way.
Old 11-06-2018, 11:34 PM   #3
ArmstrongRacing
Data doesn't lie
Step 3
Now thanks to Cranky I have plenty of this recycled braided loom, so I'll start doing the loom in sections where there are groups of connections. You can also see the mil-spec circular connector in the center, this is for a quick twist disconnect of the whole drivetrain from the car. (I'll need another plan for the starter and alternator cables).
I started with the coils, heat-shrink the end shut where cylinder 1 is, measure the distance between each plug and cut slots in the loom to feed the wires through. Tape that up with the yellow electrical tape.
Next was the injectors, followed by the crank sensor and VVT OCV's.
Old 11-06-2018, 11:36 PM   #4
ArmstrongRacing
Data doesn't lie
Step 4
Reserved for harness - alternator, knock sensor, throttle body
Old 11-06-2018, 11:36 PM   #5
ArmstrongRacing
Data doesn't lie
Step 5
reserved for harness - cam sensors, A/F sensor, coolant temp & MAF sensor
Old 11-06-2018, 11:37 PM   #6
ArmstrongRacing
Data doesn't lie
Step 6
Reserved for harness - HES connector location and chassis side routing
Old 11-06-2018, 11:37 PM   #7
ArmstrongRacing
Data doesn't lie
Step 7
reserved for harness - assemble connector
Old 11-06-2018, 11:38 PM   #8
ArmstrongRacing
Data doesn't lie
Step 8
Reserved for harness - starter cable
Old 11-06-2018, 11:38 PM   #9
ArmstrongRacing
Data doesn't lie
Step 9
reserved for harness - alternator cable
Old 11-06-2018, 11:38 PM   #10
ArmstrongRacing
Data doesn't lie
Step 10
reserved for harness - testing
Old 11-07-2018, 11:15 PM   #11
saikouguy
Drives: Toyota Echo
Impressive stuff. Will be following this
saikouguy is offline   Reply With Quote
Old 11-08-2018, 10:32 AM   #12
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I swear I'm not a hoarder, if only because I sometimes get rid of stuff. =)
Old 11-08-2018, 10:44 AM   #13
Leegamer
Leegamer's Avatar
This is awesome. Are you using a stock ecu or standalone?
Old 11-08-2018, 01:02 PM   #14
ArmstrongRacing
Data doesn't lie
Stock ECM so anyone can use it. And with the HES connector the harness is expandable to be used with any standalone or piggyback controller.
Old 11-08-2018, 06:24 PM   #15
atomic_hoji
Drives: 2018 Yaris SE 5MT
Sub'd! Looking forward to seeing this come together. Thanks for the great work as always, Tom!
-- Adam
atomic_hoji is offline   Reply With Quote
wire tuck
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
Engine Delayed Start - Toyota 1NZ-FE 1.5L SL Runner General Yaris / Vitz Discussion 9 07-23-2011 03:13 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
