Old 05-08-2016, 01:03 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Question ABS issues caused by battery/alternator??
Hi all,
I sometimes get the ABS light come on my dash. I checked with diagnostic scanner and I get the following error codes:
C1241, C1249
As this is an intermittent issue that only occasionally shows up, could it be an issue with the battery or alternator ? I have already cleaned the contacts on the ABS ECU connectors.
I am reluctant to take the car to the dealer to have this checked. I had a battery health test done and I am told that my battery is OK but may need replacing soon as its now reading 275CCA and it is a 330CCA battery. I have no idea when the battery was last replaced, owned the car for 2.5 years now with the same battery, I suspect the battery is still the same from when it came from Japan which is about 3 years ago.
JudgeM is offline   Reply With Quote
abs, alternator, battery
Noise From ABS when Braking + ABS & (!) Light On - Please Help Chris Jackson DIY / Maintenance / Service 2 04-23-2016 01:00 AM
yaris abs brake light speedometer and electric powersteering issues dave van muyden DIY / Maintenance / Service 4 10-26-2013 03:33 PM
FRONT ABS htschek DIY / Maintenance / Service 1 08-05-2013 10:14 PM
ABS brakes / Would you buy a Yaris without them? 3cyltrbo General Yaris / Vitz Discussion 66 03-26-2011 09:21 PM
What's with ABS? jgag123 Canada 9 01-01-2009 07:04 PM
