Old 07-05-2016, 01:33 PM   #1
fromthealiens
Drives: '07 Yaris sedan
'07 Yaris sedan A/C recharge...am i crazy?
Hi all, new to the forum! My wife's '07 Yaris sedan became my daily driver when I sold my Sonata last year. Have aspirations to add nice wheels/
radio/paint but first things first...A/C blows warm.
So i grabbed the recharge kit at Advance Auto and the kit's hose doesn't fit on the low pressure port on the car! Local Toyota dealer service dept and the kids at Advance had no idea what I was talking about, and nothing about this problem online. Anyone have insight on this? Would prefer to do this myself although Toyota clearly wants me to pay them a lot to do it at the dealer.
fromthealiens is offline   Reply With Quote
Old 07-06-2016, 10:44 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Is it for R134A refrigerant systems?
Old 07-06-2016, 10:48 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
sounds like u have a leak , take it to any AC shop or Toyota and have the system looked over.
Old 07-06-2016, 10:51 PM   #4
Bluevitz-rs
Not necessarily. Mine slowly went warm over the last couple years. I recharged it with a simple can of R134A and connection hose and it's ice cold again. That was over a month and a half ago.
Old 07-06-2016, 10:53 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
well its a closed system , u may have a small leak .
I would run glow in the dark die and see if u can locate it .
Old 07-06-2016, 10:56 PM   #6
Bluevitz-rs
You can only contain the system so much with seals and a spinning shaft to drive the compressor. 11 years later, some has escaped and doesn't mean there's a significant leak in the system.
Old 07-06-2016, 10:59 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
true but injecting the green stuff could resole a small problem before it gets big, also depending on the amount lost one is obligated to empty the system till issue is resolved .
by law in Canada i have to empty the system till its fixed , no top up's
just saying
Old 07-10-2016, 02:00 AM   #8
SirDigby
Drives: 2007 yaris 3 door
you should not use "A/C pro" or any recharge kit from any supplier!!! most contain stop-leak which is aerobic. if you do not use a vacuum pump to remove all the oxygen in your system before injecting, you will ruin every component in the system! also, if you do not pull system into a vacuum, you will have a contaminated system that will run poorly and inaccurate. YOU SHOULD NOT SERVICE YOUR OWN A/C SYSTEM without using the proper reclaim equipment, charging equipment, or correct training. you need proper knowledge of temperature/pressure/humidity differences as well as a real set of manifold gauges and a vacuum pump. a reclaim compressor is handy, and a filter is needed if you plan to reuse any refrigerant. DON'T PUT GARBAGE INTO YOUR YARIS!
Old 07-11-2016, 02:58 PM   #9
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The A/C on my 08 sedan is not running as cold as it once did i suspect a recharge might be in order,What would be a ball park figure the dealer would charge me to recharge the system?
Thanks
Have Yaris will travel..
Old 07-11-2016, 05:28 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Thanks
80$ to 100$ but this should involve full system check.
Sent from my Nexus 5X using Tapatalk
Old 07-11-2016, 06:29 PM   #11
bronsin
bronsin's Avatar
Thanks
Toyota evacuated mine and pulled a vacuum on the system. When the vacuum held they recharged it.
$200.
But they don't guarantee it. They say if it isn't working in 500 miles bring it back.
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 01:50 AM
Yaris Curb Weight, difference LB vs Sedan CASTREX General Yaris / Vitz Discussion 14 12-12-2006 09:50 AM
Yaris or Yaris S sedan? glockprime New YARIS Purchase Forum 2 09-12-2006 09:32 AM
