Old 07-11-2016, 12:02 AM   #1
GoodAsGoldYaris
Drives: 2007 Yaris
2007 Yaris strange engine bay related noise wtf?
https://www.youtube.com/watch?v=H34oiVCICig
Any ideas on next steps? Could it be the alternator? It's a consistent noise these days, apart from the droning noise it doesn't seem to have affected anything else.
GoodAsGoldYaris is offline   Reply With Quote
Old 07-11-2016, 01:42 AM   #2
CoryM
Drives: 2009 5-door, 5-speed
Definitely rotating noise. Remove the belt and spin/rock your water pump pulley. It may the impeller hitting the block or a bad bearing. It also kind of sounds like a diode problem in the alternator, so it could be that or an alternator bearing. You can also use a stethoscope (or a long screwdriver to your ear) to pinpoint the sound, but I bet it will be obvious once the belt is off.
It could also be timing chain, but not very likely. If you start the engine with the belt off and the noise is still there, it's timing chain.
Cheers.
Old 07-11-2016, 12:37 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
alternator but also look at water pump...from the sound i would say alt.
Old 07-11-2016, 05:26 PM   #4
jra
Drives: 2015 yaris L
While you are checking the water pump and Alt. check the crankshaft pulley, sometimes they separate from from the hub and rub the timing chain cover.
jra is offline   Reply With Quote
2007 yaris squeak/rattling noise codyshow DIY / Maintenance / Service 2 08-22-2015 11:14 PM
2005 Yaris noise in engine area dwoodpub General Yaris / Vitz Discussion 5 12-27-2010 06:41 PM
My Review of My Yaris Sedan 2007 David81 New YARIS Purchase Forum 6 09-10-2006 12:48 AM
