Old 08-31-2016, 09:30 AM   #1
gumby002
Drives: 2008 Yaris Hatchback
Belt Squeeling like a Mofo
Hello
My belt squeals.
Here is what my observations are:
-Replaced Water pump & belt a few years ago
-Replaced Alternator 2 months ago
- Belt squeals when AC is on - I live in FL...AC button is always on
- With the hood up, I can see that the belt, when squealing, is not moving.
- Belt does not squeal when the AC light is off most of the time. If it does, its for 2-3 seconds only.
- AC does blow cold air, really cold, but it takes a minute or so of the squealing and then not squealing for the air to get cold
I am thinking that its the AC unit that is causing this. Its an uneducated guess because I've replaced 2 of the 4 pulleys/sheaves already.
Thoughts? Things I should try? Am i on the right track?
Thanks!
James
gumby002 is offline   Reply With Quote
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 07:32 AM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
