![]() Drives: Yaris Join Date: Apr 2017
Toyota Yaris Drum Brake Bleed Nipples
Hello,
I'm carrying out some maintenance on a 2000 3 door yaris with rear drum brakes. The brakes feel very soft and the pedal goes straight to the floor so I'm pretty certain the line need bled (rear drums just been overhauled). However the bleed nipples are rusted beyond recognition! I'm pretty sure they'll come out but I'd like to put new ones in. Does anyone know where to buy such parts? (UK) Thanks in advance! |
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
Check your local Toyota dealer / Repairer
47547-20010 is the P/N for the bleeder screw / niple |
![]() Drives: 2008 yaris Join Date: Apr 2017
Brake bleeding
Replace slave cylinders. You will never get them out. Even soaking, channel locks, what ever you use will be tough.
Brake bleeding
Just food for thought, if bleeders are that rusty, and you had the drums turned, meaning someone ground the inside of drum till smooth, why wouldn't you want to replace cylinder. Easy enough job. Cool!
Thanks for all the speedy replies!
I contacted Toyota today and they’ve told me there are 4 different sizes it could be and the only way to know would be to whip one out and measure it! The cylinders look like new on the inside of the drum when the shoes and fittings were replaced (The fittings were in bad shape) so I would ideally like to keep them but if I can’t get the screws out tonight or they crumble in the process new cylinders it will be! Thanks guys! |
Update;
I attempted to get the bleed nipples out last night and they weren’t shifting! Figured it was time for new brake cylinders as suggested earlier but after trying to get the brake line off it appears that bolt has suffered the same fate ![]() What is the best way to move forwards from here? Is cutting the brake pipe and reflaring it with a new brake pipe connector a possible way forwards? If yes would anyone happen to know the details of the brake cylinder thread? I literally can’t see any other way of doing it
#7 | |
You can cut the line and out a new connector on and flare it (need the proper tools) or buy a new line and bend it yourself (also need proper tool)
Or bring it to a mechanic and have them do the line work. Won't cost much since it won't take them a long time. Always coat your brake lines in a fluid film and use a line wrench when doing brake lines
Try vice grips as a last resort..
#10 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
![]() As to the problem. You could try heating very carefully with a torch. I'd heat the metal that they go into more. The temperature difference might just bust the crud free and enable you to break them loose with mole grips or a good set of grips.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
Heating could damage the rubber cups and seals in the cylinders, best bet is to replace them, you can splice a new piece of brake line onto the old one but need a double flare tool, In the US you can get them pretty cheap at harbor freight, don't know what's available in the UK though.If line is pretty rusty, may be better to replace it to, you will need a tubing bender so you don't kink the new line when bending it to fit.
#12 | |
![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
Have had the bleeder screw threads strip on the back a few times, after that it would never seal properly. Sometimes you can get it out with heat and wax, or heat and water.
That doesnt work, buy some new cylinders, aftermarket ones are pretty cheap, but with my experiance, many of them ended up being garbage. Your call. You can also bleed the lines from the brake hose too if you dont want to risk breaking the screw. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
