Old 03-14-2017, 07:51 AM   #1
rabbito
rabbito's Avatar
1zz tb idle control (allen wrench)
idle stays high between 900-1000 when i drive around town...after 20 second it calms down to 750-800...everybody said chip away the epoxy and turn counter clock wise to slow the idle..felt like it wasnt calming down...so i rotated clock wise and feels like its still the same..i mean it goes down to 650rpm but still takes time...now my allen wrench fu*ked up the screw part where i cannot even spin it anymore..fml 😂😂😂😂😂
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
What size allen wrench for auto transmission drain bolt? detroiter DIY / Maintenance / Service 6 03-30-2019 02:55 PM
Engine Control Module Code and Rough Idle rks171 DIY / Maintenance / Service 4 05-13-2015 10:47 PM
I NEED Boost... Opinions puh-lease Focus_Sh1ft Forced Induction Forum 551 02-08-2013 05:55 PM
I need Help on Idle Control Parmas DIY / Maintenance / Service 5 08-11-2010 09:35 AM
