Old 04-10-2017, 10:54 AM   #1
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Water leak problem
07 H.B water leak just in the right rear floor and truck ???? Any one had the same problem any idea ??? Thank u
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 04-10-2017, 11:33 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Yaris right rear water leak
I was getting a wet place and found two possible sources on the right rear floor/seat area after a total rear bench delete. I could see ground through a hole about 3/8 inch diameter. (Even if this was for a locating prong on the seat frame, it would leak.) I covered it with a piece of PVC tape and still notice a minimal wetting at the large circular hole plug in the same vicinity.
Old 04-10-2017, 12:01 PM   #3
Yaris874
Yaris874's Avatar
Thank you bi the way how u take the backseat is easy ??
Old 04-10-2017, 12:36 PM   #4
scratchpaddy
Hubcap Enthusiast
scratchpaddy's Avatar
Drives: '09 3-door 5-speed
Check your taillights. Lots of the 2nd gen hatchbacks get leaky there. Run some water down the channel outside the hatch seal, above the taillight, and see if any of it winds up in your spare tire well.
scratchpaddy is offline   Reply With Quote
Old 04-10-2017, 12:53 PM   #5
Yaris874
Yaris874's Avatar
The leak is somewhere in there
Old 04-10-2017, 01:03 PM   #6
Yaris874
Yaris874's Avatar
Jackpot found it thanks scratchpaddy taillight
Newbie with an exhaust leak on his '06 Yaris ToYarta DIY / Maintenance / Service 49 01-03-2019 01:50 PM
Water leak in Hatch ilikerice DIY / Maintenance / Service 40 10-22-2016 03:46 AM
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 02:22 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 10:08 PM
