Old 03-17-2017, 06:52 AM   #1
bgolash
Drives: Yaris
Yaris won`t start..3rd Battery
Hi
I am getting frustrated with my 2010 Yaris. Over a 1 ½ year I`ve gone thru 2 batteries. The second battery was pro-rated and got a replacement.
That died 5 months’ latter. So I took the Yaris to the dealership in a last ditch effort to solve the problem. The mechanic mentions that Goodyear
Battery is junk. So, the Toyota dealership puts in a new battery. That is good for 8 months then the car won`t start again. Cost $300.00
Then I hear from a friend that you`ll have problems if you don`t use the car regularly. So I make a concerted effort to use it all the time. Instead
of using my Toyota Tacoma. At that point, I`m running again for months and thought the problem was resolved.
Had a big snow storm. I used the truck to plow and the Yaris sat unused for two days. It was very cold…. dead again. This is getting to be aggravating.
So…I assume its an alternator or other electronic components that are the real cause. I assume the dealership tested the electrical components but now
am even uncertain they tested anything.
When u attempt to start all you hear is a buzz. Engine makes no sounds of starting.
Thanks
bgolash is offline   Reply With Quote
Old 03-17-2017, 08:58 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Do you have any aftermarket accessories installed?
ex: alarm, or remote starter?
Old 03-17-2017, 09:10 AM   #3
bgolash
Drives: Yaris
Yes Remote Starter. Can I disable it myself. Someone somewhere mentioned remote starters can be a problem.
Old 03-17-2017, 09:45 AM   #4
Bluevitz-rs
ok, start by disconnecting that. It can be draining your battery by constantly looking for a signal.
You can also invest in small fully automatic battery charger 1A or less. You can get them with a lead that bolts to the battery and can connected and disconnected without opening the hood. Simply plug the car in if you know you aren't going to use it for a couple of days and you'll never come out to a dead battery.
Old 03-19-2017, 02:20 PM   #5
B.B._07
Drives: 07 5dr
It sounds like you have a parasitic draw on the battery that is killing the battery if you leave the car unused for a few days. You can check for a parasitic draw by using a good multi-meter or VOM and pulling fuses to isolate the draw. Here's a good video that explains the test:
https://www.youtube.com/watch?v=eXX8TfzRAKk
You can rule out your alternator by checking the voltage across the battery terminals with the car running. At idle with a few electrical accessories like the headlights and heater fan turned on you should have somewhere around 13.5V.
Old 03-19-2017, 07:20 PM   #6
bgolash
Drives: Yaris
Originally Posted by B.B._07 View Post
I sounds like you have a parasitic draw on the battery that is killing the battery if you leave the car unused for a few days. You can check for a parasitic draw by using a good multi-meter or VOM and pulling fuses to isolate the draw. Here's a good video that explains the test:
Thank you...Great Information.
Old 04-09-2017, 11:45 AM   #7
bgolash
Drives: Yaris
Dead Battery-Parasite Draw
Hi All
I did the test with the help of this video: https://www.youtube.com/watch?v=eXX8TfzRAKk
It seems the meter gives a reading of .15 DC. I assume that tells me I don`t
have a parasitic draw. Should I check the alternator next.
Just remembered this: a new problem with the car is the passenger side window will not power up or down.
Not certain when the window died but I`v been having this problem with car starting for at least 2 1/2.
Could the electrical related to the power window cause a drain.
Regards, Barry
Old 04-10-2017, 04:52 AM   #8
alias06
Drives: 2008 Red Toyota Yaris
I'd suggest re-doing the parasitic test. When you are looking for a parasitic drain you should be reading in amps, not DC. Your post above shows that you are in the wrong setting.
alias06 is offline   Reply With Quote
Old 04-10-2017, 09:54 AM   #9
bgolash
Drives: Yaris
Dead Battery
Hi, A battery is DC so wouldn`t the amps be considered DC. I`m not trying to second -guess you. Just trying to understand the theory.
I did move the probe to Amps and set the meter to 20 amps. Then took the reading. If I`m recalling correctly what I did.
For the hell of it, I`ll follow the video a second time and check myself.
Thanks for the reply!
Old 04-10-2017, 10:37 AM   #10
dogsridewith
Drives: 2007 2-door hatchback
My 91 Corolla drains about 10 milliamps w/ everything off.
Old 04-11-2017, 02:01 AM   #11
alias06
When you are reading Voltage (V) on a battery it is in DC voltage. Current is measured in Amps (A). If you are going to follow the video in the link from the previous post make sure that you do have the battery disconnected with one lead going to the negative post while the other lead has a good connection with the grounding cable. Don't forget to make sure that the meter is in the correct configuration for the test.
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Yaris 2008 does not start sberdina DIY / Maintenance / Service 8 04-06-2010 02:03 PM
Not sure where to start (2009 yaris)... Faith87 General Yaris / Vitz Discussion 37 03-23-2009 05:35 PM
