Old 02-19-2019, 06:29 PM   #1
YodaBird
Drives: Gray
Snow Bank pushed pushed bumper out of snaps ?
I hit a snow bank, more like an ice bank of snow today; resulting in my rear bumper coming out causing a half an inch gap along the seam, and around the gas tank, compared to the other side of the car.
Can it be fixed so as there is no more space ? It looks as if there are snap clips which the bumper has to be aligned and snapped in, if I'm correctly ? I tried, although unsuccessful; odds are I'll have to visit the dealer to get it fixed.
YodaBird is offline   Reply With Quote
Old 02-20-2019, 01:27 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
You should be able to snap it back into place. I had a similar situation when someone rear ended me. Was hard enough to dislocate the bumper but not hard enough to cause real damage. Just line it up to where it should be and give it a hard smack with your hand. If it doesn't go the snap clips may be broken or the tabs on the bumper may be bent. Try to straighten them out and try again. Good luck.
Old 02-20-2019, 08:01 AM   #3
logoris
Drives: 2017 Yaris SE Blue Streak
Happened to me as well, just line it up and give it a firm smack by the clip and it pops in.
its very simple to put back in
logoris is offline   Reply With Quote
Old 02-22-2019, 11:47 PM   #4
YodaBird
Drives: Gray
Anyone have a picture of the clips on the car and on the bumper ? I tried to push it on, when I think it's in, a second later it pops out. I'm not sure whether I'm pushing it in correctly or the clips are broken.
Also I realized it wasn't from an ice / snow bank as I mentioned; the car was stuck with ice and snow and some dude helped us push the car, and I believe he pushed on the bumper causing it to pop out rather then the top corner of the car. I hope the clips arn't broken due to some random guy and causing me to have to buy a new bumper.
Old 02-23-2019, 08:20 AM   #5
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
#canadaproblems
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 02-25-2019, 08:37 AM   #6
DarkShadowFox
ZIPTIES :D
Old 03-01-2019, 05:54 AM   #7
pjon
Drives: Yaris Icon+ 1.33 vvti
I had a similar problem with my rear bumper cover after reversing into a plantpot!
It would not remain clipped into place. I made sure the "tabs" on the bumper edge were all straight and undamaged but discovered that the plastic retainer strip on the car was damaged. It has slots to accept the tabs but two were opened up too big to retain the tabs.
My only solution was to buy the plastic strip - found a new one on eBay for half the dealer price. U.K. dealer £45. They are handed, right and left side. It is about 9" long and 1.5" wide. Secured by one screw at the back end, 10mm socket/spanner and hooks into the wheelarch.
Not saying that is your problem but I would inspect this retainer. The bumper cover doesn't need removing for access but does require the removal of one screw behind the rear hatch and about four of the push retainers underneath.
Also, as already mentioned, check all the tabs on the bumper to ensure non are bent. These do need lining up with the reatainer very carfully before pushing into place.
This is on eBay, U.K. However, the one I purchased was for a 2014 Yaris. Whether they are different for later versions I don't know.https://www.ebay.co.uk/itm/Genuine-T...frcectupt=true
pjon is offline   Reply With Quote
Old 03-04-2019, 06:34 AM   #8
pjon
Isn't it really nice when you try to help someone and it's just ignored?
Y'all have a nice day now.
Old 03-04-2019, 12:50 PM   #9
DarkShadowFox
oops read it wrong.
probably because this is the yarisworld forum, half the people on here cant install a CAI.
Old 03-04-2019, 01:33 PM   #10
dogsridewith
Drives: 2007 2-door hatchback
I probably could if I knew what it was.
Old 03-06-2019, 07:26 PM   #11
YodaBird
Drives: Gray
Originally Posted by DarkShadowFox View Post
oops read it wrong.
No one was ignored, I simply did not check as I don't get always email notifications. What is a CAI ?
Old 03-06-2019, 07:26 PM   #12
YodaBird
Drives: Gray
Old 03-07-2019, 08:44 AM   #13
DarkShadowFox
cold air intake, every install one, its a PITA.
Bumper replacement mchamp00 DIY / Maintenance / Service 0 07-03-2015 10:45 PM
