Old 12-03-2017, 10:20 PM   #1
Nina88
Drives: 2007 Yaris
Sounds like Yaris downshifts when I brake going down a hill?
Hi there fellow Yaris owners! I have been driving my automatic 2007 Yaris for just a couple of months. It has 140k miles and previous owner took very good care of it.
Lately I've been driving a very hilly route to work and I've noticed that when I'm going fast (~50 mph) down a hill, when I put on the brakes, the car sounds like it downshifts to a lower gear. It just makes a sound like the engine is revving, and it keeps making the sound after I take my foot off the brakes. It will continue for maybe 10 seconds while I'm coasting downhill and then it sounds like it upshifts and the noise stops. This always happens consistently when I brake while going down a big hill.
I've heard of people downshifting while going downhill in a manual car so that you don't have to apply the brakes as much. I'm wondering if the Yaris does this automatically somehow? Does anyone have any idea what else might be causing this noise?
Thanks in advance!!
Nina88 is offline   Reply With Quote
Old 12-03-2017, 10:53 PM   #2
Yeah, automatics will downshift into a gear it thinks will help slow down the car by engine braking. I've only ever had that happen in steep downhill grades tho (in rental cars).
Old 12-04-2017, 11:49 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Braking on a downhill will cause the automatic transmission to downshift. Has been the case for a few cars I've driven.
Mazda 3/5, 2002 civic, Toyota Echo...
Old 12-04-2017, 02:52 PM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yeah, what you describe is exactly what's happening.
Old 12-05-2017, 01:22 AM   #5
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The same will also happen downhill if you are using cruise control.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 12-05-2017, 09:30 PM   #6
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Can confirm what the others say. Both my Yari do that.
brakes, hill, noise, transmission
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
sounds of Yaris ;) henry33 DIY / Maintenance / Service 11 08-14-2010 08:15 PM
