Old 01-03-2018, 12:52 PM   #1
duggy16v
Drives: Toyota Yaris 2NZ-FE
2007 Yaris engine swap - 2NZ-FE to 1NZ-FE
Hello all. This is my first post. I am fairly new to Toyota. Any help will be appreciated.
Okay, existing 2NZ engine had turned a bearing and 2 conrods came through the crankcase. I would like to replace the entire engine with a 1NZ. Is this possible ?
Here in South Africa, we have 2 versions of the Yaris engine, the 1.3 vvti and the 1.5 vvti. I can get the 1.5 for a good price. What I'm afraid of is will my existing gearbox work ? Will the existing ECU work as well ? I have also installed a new clutch kit on the 2NZ before the damage. Will this clutch kit work on the 1NZ ? Will the engine mountings be the same ?
Any response would be appreciated.
Thank you.
duggy16v is offline   Reply With Quote
2007 Yaris Engine Swap tmtab8588 Performance Modifications 2 12-29-2017 02:32 AM
Yaris 2nz engine upgrade yarisgravel UK 0 10-28-2015 07:10 AM
03 Yaris 1.0 VVti Engine Swap, URGENT help needed. philwept_33 DIY / Maintenance / Service 1 05-15-2009 01:15 PM
