Old 01-06-2018, 08:16 PM   #1
bronsin
bronsin's Avatar
What effect Would a donut spare have on a differential?
Assuming you put your doughnut spare tire on one of the front wheels with that tend to mess up the differential? I mean it’s not as big in diameter as a regular wheel and my understanding is the differential needs to wheels of the same diameter to work properlly.
Or is it in fact perfectly OK to put that spare opposite a regular wheel on the front end?
Old 01-06-2018, 08:53 PM   #2
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
the manual does not prohibit
■When the compact spare tire is attached
The vehicle speed may not be correctly detected, and the following systems
may not operate correctly:
●ABS
●Brake assist
●VSC
●TRAC
●Cruise control (if equipped)
■Speed limit when using the compact spare tire
Do not drive at speeds in excess of 50 mph (80 km/h) when a compact
spare tire is installed on the vehicle.
The compact spare tire is not designed for driving at high speeds. Failure
to observe this precaution may lead to an accident causing death or
serious injury.
since its not a limited slip diff there should be no problem
i remember on some of the performance cars i had with limited slip diffs the spare had to be in front so a rear flat meant demounting 2 wheels on those rwd cars
imagine a posi rear end forced to slip continuously by mismatched tire heights
ouch!
Old 01-07-2018, 01:07 AM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The compact spare will have less grip than a standard size tyre. On the front, it wil affect youe steering, acceleration and braking. If you are only going to use it to get to the nearest tyre repairer, fine. If you have to go any sort of distance, it's probably better to put the space saver on the rear of the Yaris.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 01-07-2018, 08:33 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
With a regular open diff it will no effect. You should not if you have a limited slip diff.
However as others have said, you really shouldn't ever use a space saver on the front as 75%ish of your stopping power comes from the two front wheel. As well as steering.
Old 01-08-2018, 05:00 AM   #5
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
I agree -
But if you are some distance from the nearest place where the flat tyre can be repaired or replaced, or home for access to another jack (if owned)or some means of supporting the car and only have the vehicle jack, there really is no other option. How many of us carry around a trolley jack, axle stands etc.?
Hence, I would suspect the 50mph limit to allow for the smaller width tyre.
I have been in that situation and, if driven sensibly, it does not pose a problem.
e.g. take corners much slower, think ahead, remain a longer distance from vehicles in front etc.
mrpj is offline   Reply With Quote
Old 01-08-2018, 07:29 AM   #6
Bluevitz-rs
Originally Posted by mrpj View Post
I agree -
You need to think outside the box a bit.
Jack up the rear and replace the rear tire with the spare. Then jack up the front and put that good tire on the front. Not too difficult
Old 01-08-2018, 02:55 PM   #7
bronsin
bronsin's Avatar
Well i got to try the donut.
Picked up a nail the night befor a 6 inch snow. Went out in the am early to go food shopping and the TPMS ! was on. Flat rear tire. As I have Parkinsons and have trouble moving my hands sometimes I took the wifes car and called AAA to change the tire upon returning from shopping. Then went out driving n the snow.
Not bad!
Old 01-08-2018, 09:01 PM   #8
SirDigby
Drives: 2007 yaris 3 door
that's not really outside the box.
you should have learned this in driving class...
Old 01-09-2018, 06:51 AM   #9
mrpj
You are, of course correct. I obviously forgot to put on my thinking cap.
I still don't think there is a more substantial risk by fitting it to the front IF care is taken when driving. Toyota don't offer any preferences or warnings in the manual either. If it was that impotant, they would surely advise rear fitting only?
In the U.K. it is usually avised, when replacing tyres, to fit the new ones on the rear i.e. if changing front tyres, swap the wheels, front to back. So fitting the spacesaver to the rear sort of negates that.
We don't rotate tyres/wheels which seems to be common in the U.S. nor is it part of the sevicing schedule.
I have an old classic car and all the tyres are no wider than the Yaris's "doughnut" with no limit on speed - however the max speed of the car is not much more than 60mph!
Old 01-09-2018, 09:15 AM   #10
Bluevitz-rs
It's more about the fact that the space saver is has the same section width as a front tire on a motorcycle. You can't predict an emergency braking or steering situation, so as to be proactive, you should simply always put the temporary spare tire on the rear.
Old 01-09-2018, 09:40 AM   #11
bronsin
bronsin's Avatar
Good observation about the cross-section of the donut resembling a motorcycle tire. Food for thought!
What do you have jammed in your hatchbacks spare tire storage compartment? jayeh Off-topic / Other Cars / Everything else Discussions 4 12-24-2017 09:58 PM
TPMS in Spare? Amdkt7 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-02-2014 08:23 PM
Safe liner to cover donut spare area (after d. s. removal) nookandcrannycar Cosmetic Modifications (Exterior/Interior) 6 04-04-2014 10:50 AM
Spare tire question...................... NEexpat General Yaris / Vitz Discussion 9 08-23-2012 07:29 PM
Checking Spare tire Air xairmech DIY / Maintenance / Service 24 04-29-2010 05:00 PM
