Old 09-11-2018, 12:29 AM   #1
MISIEK
Drives: Yaris 2011 3-Door NCP130R 1.3L
Yaris 2011 Headlights
Couldn't find anything while doing a search. I'm looking for two items. My Girlfriend recently purchased a 2011 Toyota Yaris 3-Door NCP130R 1.3L Petrol Hatchback Engine: 2NZ-FE. VIN JTDJW923905175610.
I would like to know where I can purchase some funky aftermarket, good looking headlights with Projector Xenon/HID. Such as below?
https://www.youtube.com/watch?v=h1gQ_DkYizA
https://www.youtube.com/watch?v=BUW8JrDAnEg
https://www.youtube.com/watch?v=oT1LQ0cKhsU
GF's current headlights
https://imgur.com/a/3wjeMCa
I Would also like to know of any recommendations of changing the stock radio to a touch screen unit with GPS & Wifi and any solution that could possibly have dash cam and reverse camera integrated.
GF's dash photo:
https://imgur.com/a/2fpDc11
Any help would be helpful!
MISIEK is offline   Reply With Quote
Old 09-11-2018, 01:39 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You will have to retrofit them yourself or have someone do it for you. Buy good hid projectors, open up the headlights, install projectors, align the beams, close up the headlight, etc. It involves a lot of work but there are shops in your country that provide that service if you are not the diy type. Search -yaris projector retrofit- on the internet and maybe itll give you an idea of what is involved.
Old 09-11-2018, 03:55 AM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The Toyota radio is wider than a normal "2 DIN" radio. You can find side panel adaptors that fill the gap on eBay. This will allow fitting a standard 2DIN radio.
Alternately, there are radios available on eBay or similar sites that directly fit into Toyotas, and most have an input for a reversing camera. These have the advantage of plugging in directly, but are generally made in China, and the radio reception is not as good as the original.
I would be wary of fitting HID headlights. Australian Design Rules specifically prohibit retrofitting HID lights unless they were available as a factory option.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 09-11-2018, 04:15 AM   #4
Per Olof
Drives: Toyota yaris G 2014
Try Kirinavi,I have buy 8 inch android 7,2 Nougat ,shows cameras with wifi front and back
GPS etc.works very good
(GPS you have to load program, but iGO Primo works fine in the intern memory,easy to install
Per Olof is offline   Reply With Quote
2011, gps, head lights, yaris
Yaris HB headlights bambam28 Cosmetic Modifications (Exterior/Interior) 1 09-03-2011 08:43 AM
April 2011 Yaris sales: Down Thirty-Nine General Yaris / Vitz Discussion 12 05-07-2011 03:56 PM
Feeling a Bit Overwhelmed With the Choices for 2011 Yaris...Need Some Advice Britkaza New YARIS Purchase Forum 3 04-16-2011 06:57 AM
2011 yaris yaris2010RS General Yaris / Vitz Discussion 12 10-25-2010 01:37 AM
