Old 07-23-2017, 12:24 PM   #1
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
Wanna-B-Spec Yaris
Davis (Dabuu) here with a new username because I wasn't feeling the old one anymore.
I like the idea of building my Yaris to B-spec rules, even if it doesn't show up as an eligible MY in SCCA's GCR. Since I'm not planning to compete, some of my mods will not be legal, hence the wannabe.
I figure this will be a good way to compare my times with legit B-spec-ers.
Cusco Street Zero w/ Center Lock Pillowball Mounts.
F: 7kg/mm / 392lb/in
R: 5kg/mm / 280lb/in
Front dampners are not adjustable, but the rears are 14 way adjustable, already not legal for the class haha. I also like that Cusco supplies a linear spring for the rear.
The rear has been adjusted to max low since I took this picture.
The center lock idea is pretty cool by getting rid of all the rubber bushings up front, but the aluminum teeth for the spanner wrench to lock onto are so weak that the edges start snapping off when torquing down to 80nM. Should've been made out of steel in my opinion.
Previously, I had Konig Dial-Ins in 15x7 +35. They were nice and light, but subjectively they looked okay, and I didn't like cleaning all 12 spokes. So I got rid of half the spokes:
Kosei K1's 15x7 +30 in Miata Spec, ~13.5lbs a wheel. They are hubcentric to the Yaris, easy to clean, and they clear the SE's larger front brake calipers. My rule of thumb is, if the wheels clear a Miata w/ Sport Brakes, they'll clear SE brakes lol.
The wheels are wrapped in 205/50R15 Dunlop Direzza Star Spec ZII. The rears do rub, so I will need to roll them in the future.
I still have a lot of stuff to do before I get back on track, but I'm aiming for TRD Cup @ Streets of Willow on August 19th.
Update 08/31/17
2017 Yaris SE 5MT
2502lbs w/ driver and half tank
Engine:
- Stock
Drivetrain:
- TRD Quickshifter
- TRD SS Clutch Line
- TRD Black Duracon Shift Knob
Suspension:
- Cusco Street Zero F: 7kg R: 5kg
- Cusco Front Pillowball Mounts
- Bloodsports Racing Rear Beam Collar
- Custom Front Camber Lock
Brakes:
- TRD SS Brake Lines
- ATE Type 200 Racing Fluid
- Front Akebono Ceramic Pads
- Front Centric Blank Rotors
- Reae OEM Pads and Rotors
Wheels:
- 15x7 +30 Kosei Racing K1 (Miata Spec, 54.1 Hubcentric)
- 205/50R15 Dunlop Direzza DZII
Exterior:
- Cusco Front Tow Hook
- Okuyama Rear Tow Hook
Interior:
- TRD Door Stabilizers
- G's Aluminum Clutch and Brake Pedal Covers
- SRP MK2 MR2 Accel Pedal
- CG Lock
- Willow Spring's Dirt as Ballast.
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
What is it about the Yaris Ranger SVO General Yaris / Vitz Discussion 18 01-06-2015 09:45 PM
I wanna make my Yaris a Type S beaker Cosmetic Modifications (Exterior/Interior) 2 10-06-2014 08:23 PM
DIY Cruise Control for 2012 European made Yaris CTScott DIY / Maintenance / Service 1 12-27-2011 06:47 AM
Yaris T Sport UK Spec Mrgreengenes DIY / Maintenance / Service 0 10-01-2009 11:16 AM
