Old 12-18-2018, 10:42 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
After Engine Swap Downstream O2 Sensor Question
I think I have to replace my downstream o2 sensor as I'm getting a related code. I think there may be a short or intermittent open circuit as the wiring was twisted and isn't in great shape. The problem is that the 2011 Corolla connector and Yaris connector are different. Will a Yaris o2 sensor work? I have not been able to find any o2 sensor that lists compatibility for both vehicles.
2003 Yaris 1.3 engine swap help Jedi4690 DIY / Maintenance / Service 0 03-27-2018 04:08 PM
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 09:51 PM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 02:05 AM
