Old 04-03-2017, 06:50 PM   #1
tmontague
tmontague's Avatar
Whiteline Control Arm Bushing install and Review
Alright, a little late to putting it up, but here it is.
I did this in about 6 hours or so, working slow plus the time to sand and paint the LCA's to get rid of the rust that was starting.
Word of caution to those in the salt belt - everyone knows about the issue with the rear LCA bolt and how it rust/corrodes. However, the front LCA bolt for the front bushing is prone to completely seizing the shaft to the metal inner bushing sleeve. Meaning when you unscrew the bolt it will not come out, and any attempts to "shock" it loose with an impact become futile because the rubber bushing dampens the shock.
This is the worst of the 2 front bolts, you can see the rust on it
This is the hole for the front bolt
These are my 2 rear LCA bolts that have the issues. I replaced these 3 years ago with brand new ones and I cover them in anti seize and then marine grade grease. As you can see they are still in great shape. I regrease them every 2 years
This happened to me when I replaced my LCA on my '05 Vibe with 250k km on it. It took me an extra 6 hours to do the job and only one side was seized. I had to use a torch to burn out the rubber and then spin the bolt enough so that it wore a larger hole in the subframe so that the bolt and bushing could fit to come out. The larger hole isn't a huge deal since the washer on the bolt stops it from moving past the subframe hole. It is think metal on the subframe.
My Vios' front bolts weren't seized but were beginning to and my car only has 178k km on it and was oil sprayed every year for the past 3 years. Do yourselves a favor and remove this bolt and slather it in anti seize on the bolt shaft so that this doesn't happen. I had to put a pickle fork behind the bolt and pry it out as I had the impact on it loosening it. The shock wiggled it out very easily.
To access the front LCA bolt on the passenger side you have to un bolt the passenger engine mount and use a jack under the oil pan to lift the engine to fit a socket on it. Use a block of wood under the block so that you don't put too much pressure on the pan.
You can get a spanner on the ball joint castle nut without having to remove the CV axle. Just turn the steering wheel to the full opposite side of the side you are working on to increase your access. Use a ball joint separator of your choice to drop the ball joint from the knuckle. Pull the rear puck bushing out from the subfram then start wiggling the LCA up and down to "scoot" out the front bushing from the subframe.
Now that the LCA is out you can go ahead and press out the old bushings. I used a large C clamp universal ball joint press and even that didn't have an exact match for the puck bushing. It worked well enough but it wasn't easy. Toyota does not make the LCA easy to press in and out bushing due to the design.
Take pictures of the puck bushing to ensure you press in the new bushing to the right depth. It is a weird depth where both sides stick out past the LCA so pay attention when you're pressing it in. The puck bushing can be removed as you would expect with a press. Like I said, the adapters were slightly too large for the bushing and the lip on the bushing is very thin. So press it out slowly and be careful where the adapter is sitting.
For the front bushing I took a hack saw and cut off the rubber part of the old bushing that are like a flange. These "flange" pieces cover the edge of the cup on the LCA which is where the adapter need to press against. Once the rubber flange was cut off I pressed out the bushing.
Inserting the front Whiteline bushing is easy and can be done with your hands. Make sure you apply the Whiteline grease only to the knurled inside of the bushing and the outside of the metal sleeve. Whiteline bushing have a teflon outer coating to avoid squeak so don't grease that part. I pushed in each rubber end and then pushed in the metal sleeve.
To install the puck bushing I made sure the bushing voids were pointing to the ball joint and then I took a mallet and hammered it to the LCA so it was stuck in place and flush so I could start pressing it in. I had an issue with the second LCA as the hole for the bushing was not perfectly circular so that I couldn't seat the bushing flush. This wasted a lot of time as I had to start it with the press and it kept going in crooked. I finally got it seated fluch and pressed it in as far as the oem one.
On the Whiteline bushing one side is tapered to allow for easier pressing in. Make sure you press that side in and not the un tapered side.
Install the rear puck bushing first and then the front one and finally the ball joint. The rear put bushing allows movement that the front one doesn't.
You have to install metal washers on the top and bottom of the bushing when you bolt the LCA in. I put the bottom washer in place then inserted control arm on top of that and then wedged in the upper washer and used a pry bar to pry it into place. You can also put a smaller screwdriver into the bolt hole and force it around to line up the washers with the bushing.
I then loosely tightened the bolt and then wiggled the front bushing into the sub frame, this one is the easy one. I then loosely tightened that bolt and then fit the ball joint bolt into the knuckle. I then turned the steering wheel back to center and the ball joint will seat itself with a clunk. I then put a jack under the ball joint so that I could tighten the bolts down with weight on the suspension.
Injen Hydroshield Install and Review Sabretooth DIY / Maintenance / Service 12 07-18-2011 04:55 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 09:40 AM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 04:21 PM
Arm rest review Chaad32 General Yaris / Vitz Discussion 36 09-19-2006 07:42 PM
