Old 11-10-2012, 10:53 PM   #1
RUBBERDIPSTICK
Drives: Toyota Yaris Base Sedan
Help! Right side lower control arm removal
Help! When I was replacing my wheel bearings and damaged the boots on my lower ball joints. Long story short, I am trying to remove the lower control arms. The left side came out no problem. Right side not so much. The front bolt on the lower control arm hits the engine/oil pan before it can come out. I checked the manual and it tells you to remove a ton of stuff including the whole suspension crossmember! Thats crazy! Does anybody know of an easier way??
2007 sedan, 145,000 miles
RUBBERDIPSTICK is offline   Reply With Quote
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
