Old 01-22-2019, 08:32 PM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
The dangers of overfilling your gas tank
I often continue to fill my tank after the first click… just to round off the number. This article gives me pause for thought.
https://www.msn.com/en-us/autos/owne...cid=spartanntp
Old 01-22-2019, 09:57 PM   #2
SirDigby
Drives: 2007 yaris 3 door
i don't know if i would really classify those as "dangers."
i usually round to the nearest 10th cent.
i'm not scared...
Old 01-22-2019, 11:53 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
I put 1-2L of fuel easily after the first click and it's not nearly reaching the tube.
Sent from my CLT-L04 using Tapatalk
Old 01-23-2019, 12:04 AM   #4
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
I typically stop filling after I hear a second click. No problems yet, but I'll consider stopping after the first click from now on.
Hamster is offline   Reply With Quote
Old 01-23-2019, 05:48 AM   #5
dogsridewith
Drives: 2007 2-door hatchback
Toyota Yaris fuel tank fill shut off click EVAP system charcoal canister codes
If it isn't an errant half-fill click off, something happened--some tank pressure increase--at the first click shut off. Manual says to stop there. Why go against manual recommendation? There's a complicated EVAP system that wants vapor space in the top of the tank.
Old 01-23-2019, 09:54 AM   #6
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
In my case, my evap system is already on vacation.... Fill er up!
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 01-23-2019, 02:41 PM   #7
bronsin
bronsin's Avatar
I’m a one click kind a guy and have been all my driving life!
Old 01-23-2019, 09:39 PM   #8
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I'm pretty sure I fuel-logged - and as a result destroyed - my evap canister on my older Dodge Grand Caravan due to repeated overfilling. I now always stop at the click. I think I saw somewhere that a charcoal canister for the Yaris is north of $600.00 USD. Yikes!
Old 01-23-2019, 10:36 PM   #9
Hamster
Hamster's Avatar
$600? Whoa, I'm definitely stopping after the first click from now on!
Old 01-23-2019, 11:49 PM   #10
06YarisRS
I did find one for my 2008. The OEM is actually about $500.00 CAD. But, from a local dealer??? Not cheap!
Old 01-24-2019, 12:56 PM   #11
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Originally Posted by SirDigby View Post
i'm not scared...
I got a chuckle out of that.
I remember hearing something a long time ago about it not being good for the car to fill past the first click, so that's what I've done with my Yaris. Before it, I would "top off" my tanks.
At the end of the day, I don't think the added drops are worth any risk, so I'd play it safe rather than sorry. Stopping for gas a couple miles early just isn't worth it, imho.
On Instagram
On Wheelwell
Old 01-24-2019, 01:34 PM   #12
06YarisRS
Sage advice.
Old 01-24-2019, 01:45 PM   #13
ern-diz
ern-diz's Avatar
Originally Posted by 06YarisRS View Post
Sage advice.
On Instagram
On Wheelwell
Old 01-24-2019, 10:25 PM   #14
Hamster
Hamster's Avatar
And that's for the part alone, not labor. I'm no mechanic, so I would have to pay for labor on top of the part cost. And that would definitely not be cheap! I'm glad this thread was started. I will definitely stop topping off. No damage has happened thus far. But it's clearly a silly gamble with no real benefit.
WTB: GAS TANK, FUEL PUMP, EVAP HOSE, CANISTER Wisher23 Willing to Buy by private party 1 02-20-2024 06:46 PM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 04:57 PM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 02:12 PM
Full Gas Tank Noise? hoahmaru General Yaris / Vitz Discussion 8 04-10-2006 01:17 AM
