![]() Drives: Yaris 2007 D4D Join Date: Oct 2015
yariss 2007 rear wiper arm
Hi,
I have a 2007 yaris d4d. VIN start with VNK. I bought a replacement rear wiper arm 85241-0D020 however it does not fit. The original one I have is splined same as .However the new one I got with OE 85241-0D020 does not fit at all and has no splines either. Sames as Is there a different part number to search for? I got the part number 85241-0D020 using the VIN number on the parts catalogue https://www.amayama.com/. Hope you can help! |
Why are you replacing the entire wiper rather than just the blade assembly?
the first image is from an online source, mine is actually broken.
![]() ![]() Drives: '07 Yaris Liftback Join Date: Jul 2007
The only other option is 85241-52120, which also code matches for the diesel yaris. You can also double check the match on toyodiy.com.
i have a hard time beliving a diesel yaris uses a different unit than a normal yaris.....however non OE parts like this often times have no splines and get "cut" when bolting them down
| Rear wiper pressure? | Pinchlite | General Yaris / Vitz Discussion | 2 | 01-06-2018 06:00 PM |
| 2007 Yaris Hatchback Rear Wiper Arm Compatibility | Cigar_Maverick | DIY / Maintenance / Service | 4 | 12-10-2017 01:28 PM |
| Removing rear wiper | fred812 | Cosmetic Modifications (Exterior/Interior) | 34 | 01-27-2013 01:22 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| feeler: rear window wiper delay | yaris2010RS | Performance Modifications | 7 | 03-07-2011 02:25 PM |
