Old 05-30-2019, 01:57 PM   #1
Frank Necrosis
Drives: 2012 Yaris L MT
2007 Alternator in a 2012
Will an alternator from a 2007 drop into a 2012?
Frank Necrosis is offline   Reply With Quote
Old 06-05-2019, 10:45 AM   #2
Frank Necrosis
Doing some research on this and still coming up with nothing definitive.
The part number for the 2007 alternator is 27060 21150. This part number was superseded around 2009 by 27060 21151.
I am going to drop in the 2007 alternator in my 2012 and see what happens.
Old 06-07-2019, 04:28 PM   #3
seatech30
Drives: Yaris 2008 Sedan
I checked both parts in Toyotapartsdeal, and the 2012 part number shows as compatible with my 2008 yaris, so perhaps it is? They show 12V 80A spec on both. I would imagine you might just run into different connections. I can send you a pick of my alternator if that helps.
seatech30 is offline   Reply With Quote
Old 06-10-2019, 01:25 PM   #4
Frank Necrosis
The connections are the same. The 2007 alternator plugs right in.
Old 06-10-2019, 02:14 PM   #5
Jason@SportsCar
The pulley changed at some point, but I don't recall if it was with the bodywork in 2012 or if it happened later. I have interchanged the two, just swapped the pulley - it is visibly different, you can't miss it.
Old 06-11-2019, 12:45 PM   #6
Frank Necrosis
Thanks for the info. I will check the pulley.
There are two different length belts available for the 2012. The pulley on the alternator may be the difference.
Old 06-11-2019, 01:48 PM   #7
tmontague
tmontague's Avatar
is one for no a/c and the other for the a/c?
Old 06-11-2019, 09:31 PM   #8
Jason@SportsCar
Can't imagine why they would offer two belts. Don't think you could get a non AC Yaris in the U.S.
The pulley change was a shoulder on the backside of the pulley which pushed it out a few mm. Looking at pics I believe this was later than 2012, like 2015ish.
Hard to see here, but in the lower left corner you can see alt pulley with the wider shoulder:
Older Yaris alt pulley:
Old 06-12-2019, 10:49 AM   #9
Frank Necrosis
I don't think it was for an AC delete unless the delete required an idler pulley to replace the AC compressor. Some GM cars have this.
The difference in the belt is about an inch. I always buy both and return the one I don't need.
Thanks for the pics. I really hope I don't have to take the pulley off the 2012. The shaft and nut are a rusted mess.
Old 06-12-2019, 11:22 AM   #10
tmontague
tmontague's Avatar
On older Canadian yaris the diagram without a/c no idler pulley is needed. I have a similar belt set up on my 2zr and when I deleted the a/c no idler pulley was needed.
I guess the only way to know is to find the length difference
2012 dash swap 2007 yawly Cosmetic Modifications (Exterior/Interior) 15 03-16-2014 12:57 AM
2007 yaris snow tires on 2012 lomky Third Gen Yaris General Discussion 4 11-16-2012 03:00 AM
Buyout 2007 or lease 2012? Walnutcrunch New YARIS Purchase Forum 11 06-03-2012 03:19 PM
