![]() ![]() Drives: Sedan Yaris 2010 Join Date: Dec 2017
Grinding noise at low speed Trac ABS light blinking
Hello,
My LH abs cable was faulty and I got a replacement, I also replaced my steering rack (which meant I had to disconnect battery for a long time during the rack replacement). I have now noticed that when I drive I suddenly get a grinding noise even at low speed, during this period the car brake pedal pushes back and the the trac light blinks I am usually force to park. However if I then disconnect the abs sensor cable, I get the airbag and trac light on permanently but the grinding no longer happens. Though I get some little scratching sound when I apply brakes occasionally. How do I fix this please? And is it okay to continue to drive with trac and airbag lights on? |
Bump
| Low road noise in Yaris? | RedRide | General Yaris / Vitz Discussion | 32 | 05-30-2010 08:49 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Intermittent low oil pressure light. | Inspector14 | DIY / Maintenance / Service | 23 | 03-29-2010 01:46 PM |
| DIY for Low Cost Dim Light in the light LED | tang | DIY / Maintenance / Service | 0 | 03-08-2009 10:58 PM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
