Old 06-13-2019, 08:43 PM   #1
rayfloyd170
Drives: Yaris 2016 1.3 Manual
yaris AC not working
my yaris was in perfect con dition before i went for vacation for 1 month. now i came back and switched my car but AC will just make a click (compressor clutch activates) but without giving cold air.
what could be the potential problem?
What do i need to check first.
thanks
Sent from my SM-G960F using Tapatalk
rayfloyd170 is offline   Reply With Quote
Old 06-16-2019, 03:03 AM   #2
rayfloyd170
i found out that the compressor still works and it spins when the AC clutch engages.. i just went to the shop and have it re-charged with R134a and it goes well again... reached 5.3deg C while the outside temp is 45 deg C, it is fantastic.
My question is, how often do we need to recharge it with R134a? the technician checked for leakages but could not find one... he told me it is normal to have some minimal leak of the refrigerant due to rubber seals in the compressor, is that true? he also told me that my car was not running for 1 month and that could be the reason why the leak goes fast and almost emptied out the refrigerant in the system.
i am concerned there could still be leak but maybe he was not able to identify it. He just did a simple soap leak test in all the lines and told me that my system is perfect and even the vacuum was perfect...
is this really common? i hope it is...
Old 07-09-2019, 01:56 AM   #3
toyotavios_11
Drives: Toyota Vios
there is a leak
toyotavios_11 is offline   Reply With Quote
Old 07-09-2019, 07:20 AM   #4
rayfloyd170
yeah that was the only thing i can only think of, a leak... but surprisingly until now almost 1 month it is working very well since it was evacuated and re-charged with refrigerant... most likely there was a leak in the filling valve (HP or LP ports) which we were not able to notice since it was used by the manifold to check the pressures, by using the manifold maybe the seat of the valve gets corrected and sealed again... :)
Old 07-09-2019, 08:18 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
It will work , until next time it won't.
My mechanic has a device that detect leaks. When I went in for a compressor change (for my Mazda) they detected a small leak around the hoses seal on the compressor. Being 9 years old, they also changed the fittings and the seals at the same time.
Sent from my CLT-L04 using Tapatalk
Old 11-25-2019, 12:03 AM   #6
rayfloyd170
after 5 months it leaked out and replaced the evaporator. :( but it is working fine now.
Just cant believe a 3 yr old evaporator that is still physically very clean just gave up.... i also have a friend who has roughly the same 3 yr old yaris and got an evaporator leaking... i hope this isn't a common problem... the mechanic told me it could be a premature problem due to vibration or factory defect of the material... there is only a small leak on the corner fin...
Yaris High Beam Issue Only one headlight is working mik23 DIY / Maintenance / Service 10 12-30-2018 06:53 PM
Yaris 2010 beam lights not working in dash Riteshb DIY / Maintenance / Service 0 03-29-2018 02:05 AM
ABS not working on 2003 Yaris harriss UK 0 02-20-2011 05:24 AM
