![]() Drives: 2010 1.4 d4d Join Date: Oct 2014
What 15" steel wheels fit 2018 Yaris Hatchback?
I've got 16" aluminum factory wheels on my 2019 Yaris Hatch/Liftback. I'm in Canada so it's the old style made-by-Toyota in France version.
Anywho I think I should really buy 15" steel wheels and put some winter tires on there. Do Corolla, Prius, or what stock steel wheels fit? I plan on trying to find something near me using http://www.car-part.com My first choice would be an aluminum wheel but I think for cost purposes I'll probably go with steel and some OEM looking wheel covers. |
![]() Drives: 2015 Yaris L Join Date: May 2006
Probably 4x100, like prius c wheels. I think the new corollas are 5 lugs now.
![]() Drives: 2015 SE HB Join Date: Jun 2007
If you are going on the cheap, just search the local wheel shops or an auto recycling place, cookstown or carcone's
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
I would advise against aluminum rims for winter. They usually oxidize and get that white flaky stuff. A known source for many leaks. However rusy rims could cause you the same issues. Cost wise steel is always cheaper though.
As for rim size, I would think a 15" rim would be easier to find tires for these days. I dont think any cars come with 14" rims anymore. 15" is way more popular. As for what fits... basically any toyota or honda 4 bolt rim. 4x100 is the stud spacing and the center bore is 54mm. Basically the smallest center bore available. Just about any 4x100 should fit. If you're looking for a frugal setup, look on kijiji. Theres thousands of used winters already on rims available. From one season left to basically brand new. I've run many kijiji rims/tires over the years without issue.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
OK well I should update. The 15" steelies from the LE Yaris do fit over the SE Yaris brakes. They fit fine, I bought new OEM wheels from the dealer.
| 2009-2011 Yaris OEM 15" Alloy Wheels on 2012-2014 Yaris L 3/5-Door Hatchback? | Kalispel | Third Gen Yaris General Discussion | 4 | 07-09-2014 01:47 AM |
| will 2010 Yaris wheels fit 2012 Yaris? | yaris8888 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-25-2012 12:36 AM |
| WTB: 4 Stock 15" Steel Wheels (with or without tires) | kapo | Items for Sale by private party | 5 | 04-01-2011 06:35 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
