Old 04-11-2020, 07:49 AM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
Is there a simple way to DISABLE drl?
One thing I don't like about my manual Yaris is it came with daytime running lights, which gets on my last nerve. I like to control whether my lights are on or off. Is there a simple way to disable this function on the car without gimping up other stuff?
Thanks in advance.
bentjazz is offline   Reply With Quote
Old 04-11-2020, 11:01 AM   #2
tmontague
tmontague's Avatar
Look up under the dash from the drivers footwell (assuming RHD). On the side beside the radio (middle of car) there is a large connector with a lot of wires running to it. Disconnect it and you are good to go
Old 04-11-2020, 12:09 PM   #3
bentjazz
Thanks, tmontague. I'll give it a try (actually, wheel is on the left-hand side). And thanks for the helpful advice on Pennzoil synthetic oil. Will be trying Pennzoil Ultra Platinum next oil change.
Old 04-12-2020, 01:22 PM   #4
tmontague
tmontague's Avatar
Sorry I actually meant to type LHD above. So everything should be as expected other my post above
DRL disable hmsailor Third Gen Yaris General Discussion 11 06-11-2018 10:42 AM
Disable DRL on 2012 Yaris Le ucsmfu Third Gen Yaris General Discussion 12 09-16-2015 11:29 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 11:59 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 07:37 PM
Disable DRL and keep Fog Light function!! chino_potato DIY / Maintenance / Service 10 06-23-2007 02:01 PM
