![]() Drives: 2003 Vitz Join Date: Jun 2020
fuel sender units???
hello guys, just wondering if the sender units for a Toyota echo are different to the ones used in the vitz. ive recently swapped from a digital cluster to a rs analog one and the fuel gauge is showing a error by flashing all bars full then will stop flashing and show empty. so what im thinking is the senders need to be different???
any help and part numbers will be appreciated |
#2 | |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
OEM
no im not sure if the fuel senders are different
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
The JDM RS shares the same sender unit as our ADM Echo. However, the sender unit for our ADM Echo that comes with the digital dash is different. Hope that makes sense.
So did your Echo originally have a digital dash? |
Yes I converted it over to a analog dash. So I believe the sender unit is different as I went to Toyota today and asked for part numbers for them. One said fuel sender (W/digital meter /with tacho/KM/H. So I’m going to order it and hopefully it fixes the issue
Gotcha. I just looked up the parts catalog and it's that digital one that's shared across the models. Looks like part# 83320-52061
| Fuel pump, sender, seal, wiring, and cluster | mavrick | DIY / Maintenance / Service | 5 | 07-22-2019 05:34 PM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 08:55 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
