Old 09-14-2010, 06:37 PM   #1
jenfre
jenfre's Avatar
Drives: Yaris RS 2009 5DR
Replacing an 1NZFE by another 1NZFE ?
I was wondering, if you take out the 1NZFE engine from a 2009 Yaris and you replace it byt another 1NZFE engine from another yaris. Will the swap be bolt on ? I Mean : will it start at first crank or it will need the ecu to be reset or something like that ?
The reason i'm asking that : Is that a good idea for a long term boost project to buy an used 1NZFE engine and rebuilting it with forger internals etc... and swapping this one in the engine bay ?
Megan Racing Coilovers - HID 6000K - Fog Light 12 000K Blue - 50/70/90 Tinted WINDOWS - Short Shifter TWM - Rota Sliptream 16x7 Direzza StarSpec 205/50r16 - Injen CAI - R1 Concept Slotted Rotors - Carbotech Brake Pads XP8 - SS Lines - Sparco Steering Wheel - 23MM Rear Sway Bar - Ultra Racing rear, under and fender brace - Borla Axelback
jenfre is offline   Reply With Quote
Old 09-14-2010, 06:42 PM   #2
cdydjded
Drives: Yaris LB Turbo
Yes it will bolt right in & no the ECU would not need to be reset. And your thinking is also a good idea about using another spare engine. They are so inexpensive that building a spare one with forged internals is a good idea. That way you always have your original engine.
Old 09-14-2010, 06:44 PM   #3
jenfre
jenfre's Avatar
I love my original engine LOL no seriously a tought it was best to keep the good engine in case of problem etc.. and i saw few 1NZFE for less then 500 $ Is there few difference between 2006-2007-2008 1NZFE and 2009 ? Or it is exctaly the sdame thing ?
Old 09-14-2010, 06:53 PM   #4
cdydjded
They are all the same
Old 09-14-2010, 06:55 PM   #5
jenfre
jenfre's Avatar
Thank you !!! It is apreciated ! I'm starting my built this winter !! I'll have to go and learn a bit about Fuel management thought. ill go inform myselft in the turbo section forum first !!
Thank you guys !
Old 02-20-2021, 12:23 PM   #6
Socaljdmchris
Drives: 04 scion xa with jdm 1nzfe typ
Not all 1nzfe are the same. The ones in the u.s. are all the type '99, but in late 2003, there was a redesign that added adjustable lashes, rocker rollers, oil rails, and an egr. It is the type '03 and was distributed in other countries. It is mechanically different and not all parts are interchangable with the type '99 that was distributed in the states.
Socaljdmchris is offline   Reply With Quote
Old 02-22-2021, 12:38 AM   #7
remcafee
in us spec yarises the 07 and 08 have a different valve cover baffling system compared to 09+, you can see it in the corner of the valve cover their is a slot in 09+ and 07 and 08 their isnt, i dont think it really matters which one you have but getting an 09+ engine would be a better choice for having the updated pcv baffling and it helps with a little oil burning i imagine.
Just wanted to share this: turbo 1NZFE as400g33k Performance Modifications 34 04-26-2013 11:39 AM
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 11:33 AM
2006 Yaris Hatchback Replacing Stereo Head Unit help lauren24 In Car Entertainment + Electronics (audio / video / alarm) 11 07-02-2010 12:13 AM
1NZFE VS 4EFTE Parmas Performance Modifications 5 11-14-2009 12:34 PM
1NZFE K1 by Carrillo Rod interest list xBoosted Forced Induction Forum 20 01-20-2009 03:51 PM
