Old 03-20-2013, 03:25 PM   #1
Geoff Peace
Drives: Yaris 1.33 litre 2011
Spark plug torque
Does anyone know the correct torque for the spark plugs on the new Yaris. 1.33 litre. 1NR-FE engine? I have the information the plugs are ILKAR7B11. (NGK). and the torque is 15 - 20 Nm. This seems high to me, can anyone supply the correct information please?
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 03-21-2013, 01:35 PM   #2
Geoff Peace
Originally Posted by Yarflana View Post
Oh yes! I quite forgot about that. Must be old age! However I never did get a definite answer as the information given was for the 16mm.plug, the new Yaris has 14mm. The torque I have been given is 15 - 20 Nm. which seems high especially as the plugs have an anti-seize coating to prevent corrosion. Just trying to get the correct information to prevent damage by overtightening.
Old 03-21-2013, 02:00 PM   #3
38. INSTALL SPARK PLUG
(a) Using a 14 mm spark plug wrench, install the 4 spark plugs.
Torque: 20 N•m (204 kgf•cm, 15ft•lbf)
Old 03-22-2013, 02:44 PM   #4
Geoff Peace
Thankyou C.T. If anyone is to be relied upon for the correct information it is your good self. Thankyou again.
Old 08-16-2014, 07:21 PM   #5
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I have an '08 hatch back. 1.5 liter. My spark plugs don't fit in a 14 or 15 mm socket. They fit in a 16 mm socket.
_
I could be wrong, it could be the burnt carbon, but I think it is taking me 22 ft*lbs to take the old ones off.
_
I'm going with 15 ft*lbs of torque. Is 15 ft*lbs incorrect?
_
Does the addition of an extension have to be taken into account when calculating the torque?
_
there is this that I found too:
_
http://www.autolite.com/media/11853/torquespecs.pdf
_
It only gives specs for 14 or 17 mm. Is this a sign that even though mine don't fit in a 14 mm socket, that they are called that anyway?
33.7 mpg in PA
bad is offline   Reply With Quote
Old 08-16-2014, 08:06 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Honestly ur putting way to much thought in to it ...just change ur plugs ,use antsieze and snug them up that's it
sent from my S4 on Mars
Old 08-16-2014, 08:36 PM   #7
bad
Winterizing
bad's Avatar
Thanks, I did use antiseize btw. I'm still curious to any other answers though.
33.7 mpg in PA
Old 08-18-2014, 02:24 AM   #8
268i
Drives: 06' Yaris 1.3l
apparently NGK Reccomend AGAINST the use of anti-seize provided you don't leave them for 150K+ miles. Nonetheless I used it when replacing my stock ones with NGK Iridium IX plugs..
268i is offline   Reply With Quote
Old 04-27-2021, 06:08 PM   #9
jadz
Drives: 08' Yaris, 03' Sequoia
Spark plugs x Cylinder head assembly
18 N*m
13 ft.*lbf
jadz is offline   Reply With Quote
Old 05-05-2021, 02:48 PM   #10
Corben
Oldie
Drives: 2012 yaris sedan
Is a couple grunts about the same?
Corben is offline   Reply With Quote
Spark Plug Problem TickleTimeTim DIY / Maintenance / Service 15 09-07-2013 09:18 AM
spark plug momo-yx DIY / Maintenance / Service 0 03-15-2012 04:35 PM
Spark plug change . Dc1011 DIY / Maintenance / Service 2 01-29-2012 01:55 PM
Spark Plug ubospawis Middle East 11 09-01-2010 08:55 AM
spark plug 33lam Performance Modifications 25 12-23-2008 04:40 PM
