Old 10-29-2016, 09:03 AM   #1
toma
Newbie
Drives: Yaris 1.3 2006
fuel gauge disappeared, YARIS 2006, 1.3
Hi fellows,
a few days ago I took my Toyota Yaris ( 2006, 1.3 ) for a maintenance service.
After a day or two i noticed that the fuel gague has dissapeared as shown below:
does anyone know of an issue that may cause such thing?
I was already headed back to the mechanic and the one who performed the maintenance service didn't know what may cause such thing.
The red circle indicates where the fuel gauge is usually located.
Much appreciation,
Tom
toma is offline   Reply With Quote
Old 04-18-2017, 01:12 PM   #2
txusto
Drives: Yaris 2004
Hi
I have exactly the same problem, Tom. Did you know what was the cause and repaired it? Thank you so much in advance.
txusto is offline   Reply With Quote
Old 04-18-2017, 10:55 PM   #3
SirDigby
Drives: 2007 yaris 3 door
wow. that's crazy!
Old 04-19-2017, 09:48 AM   #4
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Did you try the corrective tap test?
ncp13 is offline   Reply With Quote
Old 04-19-2017, 10:01 AM   #5
Find out where your post count went, and I'll bet you find your fuel gauge there as well.
Old 04-19-2017, 12:02 PM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Hysterical!!
On Instagram
On Wheelwell
Old 04-20-2017, 02:02 AM   #7
SirDigby
hahahaha!
Old 04-29-2017, 08:58 AM   #8
txusto
Drives: Yaris 2004
To help someone else with same problem: Speedo's LCD was damaged. Really weird failure...
Old 09-24-2018, 09:15 AM   #9
ermanno
Drives: Toyota Yaris 1,3 2004
I have same problem with LCD.
ermanno is offline   Reply With Quote
Old 10-03-2018, 06:23 PM   #10
ermanno
All LCD has normal burn. that's not the problem, because I bought another and also has the same burn spot.
Inviato dal mio HUAWEI VNS-L31 utilizzando Tapatalk
Old 05-06-2021, 07:29 AM   #11
martinez07
Did you fix it? Also this is at my place in Yaris...
martinez07 is offline   Reply With Quote
Is a 2006 Yaris coupe different from a 2007 Yaris coupe? fuzzybabybunny General Yaris / Vitz Discussion 0 02-25-2016 08:09 PM
help i broke my differential in my yaris 1.3 2006 bangsapabbinn General Yaris / Vitz Discussion 2 01-25-2013 08:01 AM
Need help ASAP, fuel gauge / shipping car PolarBear DIY / Maintenance / Service 2 09-26-2012 12:06 AM
