Old 07-15-2021, 05:19 AM   #1
Ch tbt
Drives: Toyota yaris 2008
Unhappy Yaris 2008 starting problem
Hello i have a Toyota Yaris 2008 every morning it doesn’t start the engine started turns on but the engine don’t work i wait 15min after my first try then it works good. I changed the key and the 12v battery is new
The alternator work good and the engine starter is good.
Anyone can help me?
Ch tbt is offline   Reply With Quote
Old 07-15-2021, 12:34 PM   #2
Neinris
Drives: 08 Yaris 3 Door Hatchback
Does it eventually start? check for fuel pressure, maybe the fuel pump is about to give out. I also have an 08 Yaris, I thought about replacing my fuel pump, maybe even upgrading it, since another 08 Yaris owner that I know had his fuel pump replaced earlier this year.
Neinris is offline   Reply With Quote
Old 07-15-2021, 06:20 PM   #3
bronsin
bronsin's Avatar
Try turning the ignition on for 15 seconds then turn it off. Repeat five times then try to start it. It just might be the fuel pump
Let us know what happens!
Old 07-23-2021, 05:06 AM   #4
komichal
I had similar behavior... car did not start at first try, but it did start on second try.
Turned out that a fancy sticker I put close to the ignition slot actually contained some alluminium foil in it which for some reason confused the immobilizer. Everything went back to normal once I removed the sticker.
Old 07-28-2021, 01:42 PM   #5
Leegamer
Leegamer's Avatar
Wow, I bet you were glad to figure that out. I can imagine how much time I would have wasted and never figured that out. haha.
I'm a hermit named Lee
engine, problem, starting, starting / ignition, yaris 2008
New-to-me 2008 Yaris 3 door MT mittra New YARIS Purchase Forum 5 02-27-2015 03:21 PM
2008 Yaris Sport For Sale 2008er Items for Sale by private party 5 04-22-2009 10:02 AM
