Old 07-29-2014, 09:26 AM   #1
matchew76
Drives: 1.5ts
Cool injectors
Hi...I have a 2001 1.5 t sport and was hoping for some help and info about how to change the injectors like how do I get them out to start
matchew76 is offline   Reply With Quote
Old 07-29-2014, 10:14 AM   #2
1. Depressurize the fuel system first (on your MK1, remove the EFI relay in the under-bonnet fuse box) and try to start the car.
2. Remove the plastic engine cover
3. Disconnect the injector connectors
4. Remove the plastic cover over the fuel rail to fuel line connection and disconnect the rail from the line.
4. Remove the fuel rail (two 10mm bolts mount it). In theory you have to remove the entire valve cover because the fuel rail is held captive by a notch on the valve cover, but I find that I can lift the fuel rail off the injectors and maneuver it just right to allow me to change injectors without removing the valve cover. You can also cut off the end of the retaining notch with a grinder or hack saw to allow you to fully remove the rail.
Old 07-29-2014, 11:17 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Make sure you buy replacement o-rings BEFORE you try and remove the injectors. Odds are good that you will cut at least one o-ring in the process. Try to clean out the area around the bottom of the injectors to keep sand/dirt from falling into the cylinders. Also, be prepared to have gasoline spill on the engine and yourself.
Old 07-29-2014, 11:36 AM   #4
^ Excellent points.
Old 08-09-2021, 05:27 PM   #5
mik36
Drives: VERSO S
I have been looking for this information glad i found it
I have 1NRFE
i am looking to.access the fuel line to xlean injectors using the pipe method
I would be grateful if anyone can share some photos of the black connector that connect the fuel.line with metal rail how to.safely disconnect and reconnect that plug thing
mik36 is offline   Reply With Quote
Old 08-09-2021, 05:48 PM   #6
mik36
Drives: VERSO S
This is the fuel clamp or connector
https://parts.longolexus.com/oem-par...-no-2384121050
Is there a safe way to disconnect and reconnect
Old 08-16-2021, 05:25 PM   #7
mik36
Drives: VERSO S
Anyone
Old 09-02-2021, 11:55 AM   #8
mik36
Drives: VERSO S
I have 3 efi fuse
20A FUSE
7.5A FUSE
10A FUSE
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
Stock Injectors = Maybe? Big NO? maxthehax Forced Induction Forum 3 12-10-2012 05:29 PM
FS: DeatschWerks 550cc Plug/Play injectors Tamago Items for Sale by private party 4 06-27-2012 11:11 PM
1ZZ Injectors on NA Setup MGargano Performance Modifications 14 04-22-2010 01:02 AM
Technical question about bigger injectors LtNoogie Forced Induction Forum 1 08-14-2009 03:34 PM
