Old 06-10-2007, 03:16 PM   #1
Moore
Moore's Avatar
Drives: 2007 yaris 3dr ce
high pitch whine at 100km/h
I started getting this last night. When I get to, or very close to 100km/h there is a high pitch whine coming from the engine, or somewhere in the front end. As soon as I lay off the gas it stops, but starts again when I hit the gas. Has anyone else experienced this. Does anyone know what this could be?? I have just over 1000km's on the car if this helps.
Moore is offline   Reply With Quote
Old 06-10-2007, 03:58 PM   #2
i've never experienced this.
Old 06-10-2007, 04:17 PM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
Is it only at 100km/h, or does it start there and sustain above that speed?
Can you determine if it is from the engine, transmission or steering/suspension/wheels?
Is it a mechanical whine, or an air movement whine?
- Brian
Share the Road
Old 06-10-2007, 10:59 PM   #4
Moore
Moore's Avatar
It is not from the air movement, it is defitnetly mechanical. It is not ear shattering, but it is there. It sounds like it is coming from the front of the vehicle. I am assuming the engine because the second I lift my foot off of the gas it goes away, and comes back just as quick when I hit the gas again. Starts there and sustains it(from 100km/h).
Old 06-11-2007, 02:11 AM   #5
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
do you have a power adapter plugged in? sometimes you get a whine in the speakers from the motor during high rpm.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 06-11-2007, 03:05 AM   #6
yes, I'm thinking electrical interference causing the whine in the speakers, very common thing to happen...
Old 06-11-2007, 08:59 AM   #7
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
Ion flux capacitors. They always kick in just before the thermal couplings engage, which reduces the quantum-level stress on your frame. Nothing to worry about!
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Old 06-11-2007, 10:03 AM   #8
kurokoma-kun
Drives: 2007 Yaris HB
or a phaser on overload, have you checked all the ventilation ducts?
Seriously though, could it be a belt slipping? Or does that only happen at low speed?
my yaris, kurokoma-kun
Old 06-11-2007, 11:36 AM   #9
drifto
drifto's Avatar
lol most likely not a belt, usually only hear belts during start-up or during parking(but we dont have hydraulic steering anyways ).
07 Yaris LB 5spd
Old 06-11-2007, 07:22 PM   #10
Rizzo
Rizzo's Avatar
Drives: 2007 5-Door Hatchback
When I was trying to destroy my engine by driving in third instead of drive (um, not on purpose *cringe*), it would get noisy at 100km/h. No high pitched whining, though. You're sure you're in the right gear?
Rizzo is offline   Reply With Quote
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Tranny Whine jmjonesey DIY / Maintenance / Service 11 05-23-2007 10:32 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
