Old 05-01-2009, 07:57 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Question for people with ScanGauges
What's the highest throttle position that you've seen on the ScanGauge while at WOT?
Old 05-01-2009, 07:58 PM   #2
70%
Old 05-01-2009, 08:00 PM   #3
LtNoogie
LtNoogie's Avatar
Ok, I thought I was at WOT and the most I saw was 66%. I was looking for 100% but I guess that's not the case. I was thinking do I have to push the pedal through the firewall to get 100%?
Old 05-01-2009, 08:06 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
drill a little hole in the throttle body and run a cable to manually open the butterfly flange to 100%, lol, like a little pull knob on the dash.
JK
Old 05-01-2009, 08:20 PM   #5
LtNoogie
LtNoogie's Avatar
I am making videos of the data. Should be ready shortly.
Old 05-01-2009, 09:32 PM   #6
Pretty close to what I did.
Old 05-01-2009, 09:48 PM   #7
50MPGDream
50MPGDream's Avatar
Drives: 07 Yaris LB, 93 Camaro
I just wanted to clarify the TPS readout is not a %. (i've never been at WOT in this car so i have no real contribution to the OP (I'm generally around 21-23 on the TPS readout :) ))
-Aaron
50MPGDream is offline   Reply With Quote
Old 05-01-2009, 10:11 PM   #8
LtNoogie
LtNoogie's Avatar
It can be interpreted several ways.
From the ScanGaugeII manual:
"In some vehicles, a closed throttle will read 0 and full throttle will read 100. Other vehicles will have a higher value than 0 for a closed throttle and an open throttle value less than 100."
From my Dyno-Scan manual:
"the absolute throttle position (not the relative or learned) throttle position. Usually above 0% at idle and less than 100% at full throttle."
Old 05-02-2009, 12:09 AM   #9
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
81% is the max i can get ,
Old 05-04-2009, 11:10 PM   #10
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Mine says 80% max, but I did visually confirm that the throttle plate is actually wide open.
Old 05-04-2009, 11:14 PM   #11
LtNoogie
LtNoogie's Avatar
Oh, that's interesting that the throttle plate is wide open. I thought that maybe WOT was calibrated for some lesser opening.
Old 05-04-2009, 11:19 PM   #12
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I don't remember for sure, but I don't think that's a percentage, it's a count.
The ECU is measuring the voltage being returned by the pedal position sensor. Think of it as 0 = 0v, 2 = .1 volts, 4 = .2 volts... and 80 = 4 volts. Those are just guesses, but it's probably something along those lines, as it's likely a 5 volt circuit.
Don't assume that because it's not reading 100 that you're not getting 100% actuation, as that is not how it works.
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 01:38 PM
So question here abt hatchs in general Jem_hadar General Yaris / Vitz Discussion 12 01-06-2009 04:06 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 11:27 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 06:44 PM
