Old 09-16-2017, 05:18 AM   #1
Kubcat
Drives: 2006 and 2013
Hard starting when cold, runs fine
We have a 2006 1.3L automatic Yaris. We are up to 150,000kms. Has run great, no issues at all except a slight hesitation then surge when taking off for the last few years.
I cleaned the throttle body a number of times and replaced spark plugs with no change.
I purchased new injectors and fitted them a couple of weeks ago trying to make it take off smoother but they didn't come with the seals. The old seals were hard and as expected they leaked.
I ordered new seals, refitted the injectors and the care drove a little better, I think, the hesitation/surge is still there but perhaps less.
After about a week though the car has become hard to start when sitting for more than 10 minutes or so. It needs to crank quite a bit, sometimes two goes to start. The car has the auto start feature that once you turn the key even if you let go, it keeps cranking.
It has had hard starting very intermittently in the past, but now it does it every time.
It feels like it is losing fuel pressure when it is switched off. This is confirmed by disconnecting the fuel line that feeds the fuel injector rail, no petrol squirts out like it used to.
If I attempt to start it within a few minutes of turning it off, it starts perfectly.
Except for the slight hesitation/surge, the performance is pretty much how it has always been. It revs cleanly to the redline and idles smoothly.
As I am not seeing any leaks, perhaps it is the injectors leaking or there is something going on in the fuel pump/regulator module in the tank.
Not sure how to check either so I am stuck.
I was going to remove the fuel pump module and replace the filter as it is due in the next 10,000 kms anyway but don't know what to look for in terms of what can be wrong.
I guess I could put the old injectors back in and see if the leak is at that end.
Any ideas on what to do next would be most appreciated.
Kubcat is offline   Reply With Quote
Old 10-09-2017, 03:32 AM   #2
Kubcat
Just an update.
I replaced the fuel filter unit.
I used an aftermarket unit. Wesfield WCF232.
The parts that I needed to keep were the fuel pump, something that I think is the pressure regulator, the screen that keeps the very course particles out and the float switch.
The problem has now dissapeared, the car starts and runs fine. It still has a slight hesitation and then surge off the mark as it did but not as bad.
It has always been there and our 2015 Yaris that we purchased from new also does it but not as pronounced.
Maybe it’s just me.
It has been only two days but it has started every time so far. If that changes, I will post another update.
Old 10-09-2017, 08:51 PM   #3
ex-x-fire
One of the first things to check on a fuel injected engine is fuel pressure and bleed down rate.
Old 10-28-2018, 08:30 AM   #4
lockmanz
Drives: yaris 2 1.3 vvti 2006 230 000
Hello,
i have exactly the same problem after i change my fuel filter and today i am trying to solve this problem.
lockmanz is offline   Reply With Quote
Old 10-28-2018, 02:38 PM   #5
Hoodyjay
Drives: 2007 Toyota Yaris Sedan BASE
Just an update.
Maybe it’s just me.
Is replacing fuel filter a DIY?
Hoodyjay is offline   Reply With Quote
Old 01-02-2022, 07:36 PM   #6
skwira001
I know this is an old post, but I think I found the solution. It's condensation. I poured Heet yellow bottle multiple times this winder and my car now stars much better. As the original poster said, it's not a complete fix, but it doesn't sound like it's super choked off.
Heet is the only product that will mix with the water to burn it out.
I just starting pouring in the red bottle of Heet now so I can keep the water out and clean the engine with it.
I started having this same problem beginning with the 2019-2020 winter. I replaced the battery in the fall of 2019. Once it became winter, the problems started. Then in July 2021 they replaced my battery and gave me a discount since the battery did not even last 2 years. The dealer told me the reserve capacity was failing which is used primarily when it gets cold. Well guess what, when the freeze came back, the "good" battery didn't solve the problem. But thankfully Heet did. And I just started the car in sub 0 temperatures this morning and yes it cranked a few more times but nothing like what it was doing. Maybe a couple more cranks than a perfect 75 degree day.
skwira001 is offline   Reply With Quote
Old 01-03-2022, 09:58 AM   #7
ToryBlaker
Drives: BMWx1
fuel pressure and bleed down rate should always be checked.
fit fly
ToryBlaker is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
yaris hard starting when hot, fine when cold ianpog DIY / Maintenance / Service 11 08-12-2015 10:24 PM
chirp/squeak noise just off idle when cold tadc DIY / Maintenance / Service 14 02-20-2011 04:09 PM
hard starting after moving car gonzo452001 DIY / Maintenance / Service 12 06-09-2007 06:07 PM
