Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > NY / NJ/ CT / PA
Old 10-30-2022, 11:01 AM   #1
MyCarWasFree
Drives: 2010 Yaris 4 door hatch
Newbie
Hello everyone. I just got a 2010 Yaris given to me. 250k miles but it’s going to just be a nice little commuter car with some fun stuff added. I’m on here looking for recommendations. I see things about the 1ZZ throttle body that looks easy enough. But I’m going to need exhaust maybe a header and would like a real cold air setup not a hot air cone filter bs. k&n is pretty proud of theirs any other options out there? Car runs and drives. I’ve never owned an import just older vehicles an classic v8’s so this might be pretty fun. And I will be looking for used aftermarket parts and upgrades as well. I’m a mechanic by trade anyways so let the free Yaris project begin. Thanks guys.
MyCarWasFree is offline   Reply With Quote
Old 10-30-2022, 01:18 PM   #2
bronsin
bronsin's Avatar
Automatic or manual? Two or four door? Hatchback or sedan? I am in New Jersey too near Philly
Old 10-30-2022, 07:00 PM   #3
MyCarWasFree
It’s an auto, four door, hatchback. I’m on base at McGuire.
Old 10-31-2022, 07:53 PM   #4
bronsin
bronsin's Avatar
Good luck with it! It’s a great little car. You might run a Compression check and have a look at the spark plugs to determine engine condition. If the engine looks good, have the wheels off and check the brakes. Even if the pads are good, you might want to Bleed bleed them.
Let’s see what else I can think of you can check?
Old 11-01-2022, 01:47 AM   #5
red_egg
red_egg's Avatar
Drives: 2008 Yaris Hatch
I did a very low buck cold air intake, as per this video:
https://www.youtube.com/watch?v=hOt8sKu90Po
Seems to have improved power and mpg very slightly.
I picked up a 2AZ throttle body part# 22030-0H030 from a Camry to put on my
1NZ, but haven't gotten around to it yet. The 2AZ throttle body has an easy to
access idle screw, whereas the 1ZZ throttle body has the idle screw under factory
epoxy that can be very difficult to deal with. I intend to duplicate the position of
the 1NZ butterfly idle setting on the new 2AZ throttle body using an OBD II reader.
From what I'm reading, doing this should eliminate the high idle on startup issues.
red_egg is offline   Reply With Quote
Hey guys, newbie here! Cezza07 California 6 06-04-2018 05:23 PM
Embarassing Newbie question Chicken Little Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-13-2013 12:17 AM
Newbie.. marvin0920 General Yaris / Vitz Discussion 7 09-20-2010 05:49 PM
Newbie ? lifthard1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-04-2007 12:47 AM
