Old 04-24-2022, 07:53 PM   #1
gnx547
Drives: 07 Yaris
2007 Yaris manual trans shifting from 2nd to 3rd not smooth
2007 yaris 5 speed with 106k miles. Shifting from 2nd to 3rd isn't smooth like all the other gears. I changed the fluid using Valvoline 75-90 conventional and I also lubed the shifter and still the same. Should I use synthetic gear lube? Does anyone else have this issue?
gnx547 is offline   Reply With Quote
Old 04-25-2022, 06:18 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Synchro might be failing, how does it sound and feel when you go from 2 to 3?
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 04-26-2022, 08:12 AM   #3
gnx547
Drives: 07 Yaris
When shifting from 2nd to 3rd, there's a little resistance but there's no grinding noise.
Old 06-07-2022, 09:37 PM   #4
slayazu
Drives: 08 Yaris Base 3dr
I have a similar issue, I changed my gear box oil (Royal Purple) and it felt brand new. Though I do have a leak and the problem is beginning to occur again.
slayazu is offline   Reply With Quote
Old 06-16-2022, 07:10 PM   #5
gnx547
Drives: 07 Yaris
How many miles did you put on the car using the Royal Purple before the problem started again?
Sometimes now I just shift from 2nd to fourth.
Old 06-22-2022, 09:39 PM   #6
nesagwa
Drives: 2007 Yaris Hatchback (US, MT)
Mines always been a little rough/grindy going from 2 to 3 unless I make sure the my speed and rpm are fairly low (under 3000). Not sure I want to know what it would cost to fix.
nesagwa is offline   Reply With Quote
Old 07-30-2022, 10:15 AM   #7
gnx547
Drives: 07 Yaris
Has anyone used 75W80?
2007 Toyota Yaris Hatchback Manual - Make an Offer! Southern Ontario Canada hodginsa Cars for Sale by private party 4 09-20-2019 08:37 PM
Dropping the tans in a 2zr swapped Vios tmontague Performance Modifications 2 04-29-2017 08:29 PM
2007 Yaris: jerky part throttle and trans. freewheel Cartel General Yaris / Vitz Discussion 0 03-04-2017 04:19 PM
