more stupid exhaust questions
working with an 07 5dr
whats the difference between a 4dr axle back pipe and a 5dr?...is it just tip placement or is there other things at play here..i assume the front section of pipe is the same 4dr/5dr?...for that matter is the axle back the same on a 3dr and 5dr? looking at the car and manuals..am i right in this more or less..im assuming header, cat, cat, bend, resonator, bends to joint ,joint axle back, muffler, tip im looking for flow not noise..quiet is nice and usefull tho a lil rumble when deep in the pedal i wont argue with |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Sedan tailpipe after the muffler is longer. AFAIK there is no difference between 3dr and 5dr axle backs.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
#3 | |
how about the mid pipe section..is a 3dr and 5dr the same there?..i assume the wheelbase is "close"...obviously the 4dr is what 3-6 inches longer than the 5dr in the mid section...but im not sure on the 3dr being the same part? |
3dr/5dr header to exhaust tip identical.
ok soooooo the DC fell thru
but...i got wondering, the XB ran the 1nz, and dc offers a long tube for those..heck theres even chineese knockoffs on ebay...for CHEEP, how much different is the header? i cant find any usefull shots of the yaris dc header im no stranger to welding and fabbin ..im just wondering if maybe the XB might be the better route |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
if you can weld thick manifold flanges, then yeah you should get it to fit easily, i have a small mig welder from harbor freight and all my welds were a disaster with porous holes all around my welds so i just gave up
#7 | |
i wouldnt wnat to do a head flange without having a spare head on a bench..too high a chance of warpage due to the heat required...ive got the gear to do it tho |
| Exhaust Manifold to Pipe Donut Gasket | yarisinpa | DIY / Maintenance / Service | 1 | 06-29-2017 03:35 AM |
| Hole in my Exhaust? Losing Coolant? | Peloton | DIY / Maintenance / Service | 7 | 02-02-2015 07:51 PM |
| TRD Exhaust and TRD Header questions | Liquidus Ocelot | Performance Modifications | 8 | 02-23-2014 02:58 PM |
| Exhaust sound "scientific" testing | ezhacker1 | Performance Modifications | 2 | 01-26-2014 12:04 AM |
| FS: Thunder Axle-back Exhaust for Yaris LB | FunctionSpec | Items for Sale by private party | 38 | 06-03-2010 02:33 AM |
