![]() Drives: yaris hatch 08 Join Date: Nov 2010
foglight help
Ive searched , maybe not well enough but for the last 2 hrs. Im installing a mi foglamp kit on a 08 3dr lb. my issue is my lamps do not come on and the switch is constanly lit up. Im using the swutch from the kit and pin 3 on the stalk connector is conected to nothing when i unplug it and look inside the other end? If someone could direct me to instructions on using the supplied switch i would appreciate it
Pin 3 on the stalk is not used unless you have a stalk with the fog switch on it. That is why there is not a pin there. If everything else is wired correctly and the foglight relay is plugged in to the under dash fuse panel, then jumping pin 3 to pin 4 on the stalk connector will make the lights come on (provided that the headlight switch is in the on position as well).
wich one is pin 4 in coralation to 3. and the relay is in.
1.5 or 2.5 both=0-60 in 8
Scott,
I bought one of these off of ebay and will install it this weekend have no idea how to wire this, any instructions would be greatly appreciated. Thanks in Advance and we shall call you Yaris Guru
| HELP!!, HOW TO INSTALL FOGLIGHT YARIS SEDAN?? | shangapol | DIY / Maintenance / Service | 12 | 11-28-2012 12:53 PM |
| Stock/aftermarket Foglight Question? | Yaris4L1fe | Cosmetic Modifications (Exterior/Interior) | 19 | 06-23-2011 06:47 AM |
| FS: Foglight Switch including Relay | AzNguy | Items for Sale by private party | 4 | 10-19-2009 11:04 PM |
| WTB: 06 Hatch Foglight Covers (non foglight) | hasher22 | Willing to Buy by private party | 2 | 06-24-2009 12:35 AM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
