Old 01-20-2023, 07:53 PM   #1
sh0rtlife
cat no cat?
fresh kill at the local pick n pull a 2dr 08 that had been played with
someone had clearly ripped out the cold air which by the holes in the bumper im going to guess was the TRD unit or some such "short ram" pipe(3 BIG holes beside the headlight)..even had a trd badge on the grill(snagged it)
some aftermarket header, down pipe cat back and axle back all in what looks to be 2.5.....i grabbed all of it...but looks like the can got ripped off the end, but its got a "test pipe" ala NO CAT...which begs the question, will a yaris run without throwing codes with no cat?...i know some cars will and some wont but this one was obviously being ran no cat....never mind the inspection and EPA BS..im more concerned about engine codes...we dont have inspection here..just a peek at the obd and we are on our way...every 2 years
it also had a brand new TB that looks a lil bigger..1zz?..pics to come
new vvt soilinoid
new coil packs
new injectors
new o2 plus another new o2 still boxed under the seat
new 1 inch spacers on all 4 corners, new vented sloted discs(didnt need didnt grab..may go back)
aftermarket springs....didnt feel the need with it being on stock struts
after market shifter
steering wheel adaptor
and some other trinkets...
i grabbed most everything for a total of 70$..to which i know the TB is worth more than that..never mind the complete exhaust, coils, injectors, spacers, shifter, o2's, steering, vvt
debating if i should go back for the new rotors and the rear wing..its the same unit i have..and i guess spare rotors are always worth having on the shelf..was really hoping for suspension bits...but it was stock down there
https://row52.com/Vehicle/Index/JTDJT923785207300
Old 01-20-2023, 10:57 PM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
Sweet score! The header alone was worth that!
I was going to cut my cats out lol..so good question.
Compeer is offline   Reply With Quote
Old 01-21-2023, 12:07 AM   #3
sh0rtlife
ive had a handfull of cars that passed emissions testing WITHOUT cats with only "test pipes" so i cant help but wonder if the yaris is in that same boat
the header has no "brand" on it and could be any ole generic pos, i only grabbed it cause well it "might" be an improvement..the rest of the exhaust will deffinatly be an improvement...just gotta figure out what to put on it for a muffler...gotta rummage thru my spares n see what ive got that might be acceptable...that wasnt made for a v8 lol
Old 01-21-2023, 11:00 PM   #4
remcafee
i believe to get no codes for no cat, you need a 90 degree o2 bung, i tried a straight one before it didnt work
Old 01-22-2023, 02:25 AM   #5
sh0rtlife
sooo one of these?
https://www.walmart.com/ip/Areyoursh...Bung/712266050
Old 01-24-2023, 05:22 PM   #6
Neinris
Drives: 08 Yaris 3 Door Hatchback
Originally Posted by sh0rtlife View Post
use it just on the downstream O2 sensor.
Neinris is offline   Reply With Quote
Old 01-23-2023, 11:17 AM   #7
remcafee
yes
Old 01-24-2023, 02:12 PM   #8
sh0rtlife
as sooon as ive got time and find a can for the back ill have to do some tests
Old 01-24-2023, 05:20 PM   #9
Neinris
Are both cats gone or just the second one after the downstream O2 sensor? Also, no resonator?
Old 01-25-2023, 12:25 PM   #10
sh0rtlife
its just pipe from header all the way to where the muffler should be...looks like it might be stainless..hard to tell
i found a stainless stright thru can and tip in my stash but i suspect a straight thru with straight pipe is going to be obnoxiously loud lol
P0420 after New cat, help please. Col748 DIY / Maintenance / Service 6 01-23-2017 07:22 AM
The Official *MAD DOG* jokes thread v2 *MAD DOG* Off-topic / Other Cars / Everything else Discussions 771 05-22-2013 11:25 AM
Cat lovers, Cat haters, this is a MUST READ *MAD DOG* Off-topic / Other Cars / Everything else Discussions 0 10-14-2012 06:20 AM
High flow cat question AzNguy Performance Modifications 2 12-20-2009 05:51 PM
New CAT Converter story.... jlift DIY / Maintenance / Service 14 06-03-2007 01:23 AM
