Old 01-28-2020, 03:49 PM   #1
Rob888
Drives: 2010 Yaris 2 door hatchback
Need front wheel alignment specs
I made a camber tool that consists of two bolts attached to a metal bar to which is attached a digital level gauge.
These are the angle measurements I got on all four wheels on my 2010 Yaris two door hatchback:
front driver side=88.25 degrees, front passenger side=87.39, rear driver side=89.17, rear passenger side=86.82. So, for example, the front driver side camber would be:90 degrees-88.25=1.75 positive camber I believe. The tool displays zero degrees when laid on a flat surface.
What are the factory camber specification degree ranges for the front and rear wheels?
I adjusted the toe alignment on this car using a string method. I set the front wheels toed out 1/16" on each wheel for a total 1/8" toe out. One sixteenth toe out per wheel is typically recommended for front wheel drive vehicles. What is the factory toe specification range in inches for a 2010 Yaris two door hatchback?
I found this table of alignment specs for my Yaris, but I'm not sure how to read it. https://www.autozone.com/repairguide...96b43f81b3d92d
Does the table say that the camber spec range for the front wheels is -.34 to -.50 degrees and for the rear wheels is .04 to .20 degrees? The toe spec range for the front wheels is listed as 13.07 +/-.75. Does that toe range mean 13.07 degrees +/- .75 degrees in relation to a straight line parallel to the car and through a perfectly straight front wheel? What is the spec toe range in inches? Thanks for any replies.
Rob888 is offline   Reply With Quote
Old 03-05-2020, 04:52 PM   #2
Rob888
I found all the specs by doing some searching. Thanks for the help.
Old 04-13-2023, 12:00 PM   #3
Allive
Drives: 2007 Yaris 1.5L
Hi, I’m looking for the same specs, but for a 2007 yaris 3dr HB. Can you please post your findings.
Thanks,
R
Allive is offline   Reply With Quote
looking for torque specs on front caliper bolts 07 yaris mikee07 DIY / Maintenance / Service 2 10-21-2012 04:36 PM
Alignment Specs Question xnamerxx Tracking, Racing, Auto-X Forum 20 06-26-2012 01:14 PM
Front Passangerside wheel bearing yaris4062007 DIY / Maintenance / Service 5 03-09-2012 02:34 PM
Damaged Front Bumper PLEASE READ!!! Wheel Cover?! christolphe Cosmetic Modifications (Exterior/Interior) 8 04-23-2010 12:52 AM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 08:01 AM
