Old 08-16-2023, 01:12 PM   #1
joffficer
Drives: 07 Yaris HB
2007 2dr HB part out
Hi,
I've decided it's time for my 'golf cart' to go. Unfortunately, the New England salt has claimed the underside. Suspension, rear brakes and wheel bearings are failing as well. Too bad really, because the car fires right up no matter what temp! Clutch and transmission shift smooth, too. Interior isn't bad either.
I'm considering selling off parts. Let me know what you might need, and/or offer. There's currently 110xxx miles on the odometer.
Thanks,
J
joffficer is offline   Reply With Quote
Old 08-17-2023, 01:10 AM   #2
remcafee
do you have the original climate cpntrol panel and radio bezel with the ac vents? ill take those, and please leave the knobs and vents in it as the little tabs that hold them in usually break if you remove them, lemme know how much you want, shipping to zip: 85295, gilbert,az
Old 08-17-2023, 07:06 AM   #3
joffficer
Drives: 07 Yaris HB
I do, but can you tell me how to remove (without breaking)?
Old 08-17-2023, 06:00 PM   #4
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
You have to take the trim that runs down each side of the radio/climate controls first. Then the other pieces just pop right out.
Here's a video of the stereo removal but pretty much tells you what you need to know. Start at 2:40 for trim removal.
TommyWasabi is offline   Reply With Quote
Old 08-17-2023, 07:04 PM   #5
remcafee
yes, so first pull up the side panels where the hazard switch is, then pull out the other side that has the passenger airbag indicator, then the instrument cluster panel pulls out, then pull the radio bezel out with the ac vents in tact, then the climate control panel, you can just cut the wires if the car is getting scrapped
Old 08-17-2023, 10:41 PM   #6
joffficer
Drives: 07 Yaris HB
Had it out before I even read this... A no brainer, really! :-)
Send me a message on it.
Old 08-18-2023, 05:57 PM   #7
LostinSpace
Drives: 2010 Yaris
I would be interested in the stock airbox and the hood prop, need both shipped to 68510
LostinSpace is offline   Reply With Quote
Old 08-18-2023, 05:57 PM   #8
LostinSpace
Drives: 2010 Yaris
Also the floor mats if you have them
Old 08-22-2023, 06:32 PM   #9
axiom
axiom's Avatar
Drives: 2007 Yaris
Do you by chance have a tachometer built into the speedometer?
axiom is offline   Reply With Quote
Old 08-23-2023, 09:32 AM   #10
joffficer
Drives: 07 Yaris HB
no, just the speedo.
Old 08-25-2023, 10:37 PM   #11
joffficer
Drives: 07 Yaris HB
It's all gone
Old 09-09-2023, 01:41 PM   #12
JustFPV
Drives: 2006 Yaris 2dr hb manual
Cars gone or the speedo? I'd take the drivers side headlight if available
JustFPV is offline   Reply With Quote
$700 2007 Yaris 2DR Hatchback hodginsa New YARIS Purchase Forum 63 11-13-2017 12:36 AM
2007 Yaris: jerky part throttle and trans. freewheel Cartel General Yaris / Vitz Discussion 0 03-04-2017 04:19 PM
DIY - Carbon fiber wrapping Brian Wash, Wax, Detailing, Exterior Repairs 15 07-10-2016 01:34 PM
2007 Registration and Insurance Vitz-to General Yaris / Vitz Discussion 21 03-28-2006 10:57 PM
