GRIDLIFE Sundae Cup Yaris
Drives: 06 CDN Yaris Base Join Date: Apr 2017
2ZZ-GE Swapping my CDN 06 Yaris Base
Hello everyone! I thought I would start a thread to document my process of swapping a 2ZZ-GE in to my Canadian imported 2006 Yaris Base. Currently the car is running the stock 1NZ and stock C50 trans and clutch, with a Garrett GT2048 turbo running 8psi un-intercooled on E85 through a Speeduino. I finally have another car to drive to work, a 2003 Matrix XRS.. which is what made me fall in love with the 2ZZ, so the 1 ton of fun Yaris is finally going under the knife! I plan on using this car as a time attack and hpde machine so I wanna cage it and make it full race car. Currently it has full interior, running a custom set of Air Lift Performance bags, Konig Helium 15x8s and a Whiteline rear sway bar. And yeah, I know, 2ZR is much easier.. but I do not care if its easy! If it was easy, I probably would not do it
Anyway I have most of an engine and trans from a 04 Matrix XRS that I scored from the local U Pull yard for $300 so it is getting a C60 along with the 2ZZ. I will try to update this as much as possible as I move forward with the build. For now, here I made you some content:Ripping around Gingerman Raceway at West Michigan Honda Meet when it was still almost stock, engine wise: https://youtu.be/mgwyyaAdAOk?si=ZFC4N9RwlfUnBbHt |
| 2010 yaris hatchback base (more power) | 2010yarisHBbase | Performance Modifications | 13 | 03-22-2021 05:18 PM |
| TB 2zz fe on yaris 1500cc? | Nets | Performance Modifications | 3 | 05-12-2010 09:06 AM |
| Installing a rear facing infant base in a Yaris | Stacy Travis | General Yaris / Vitz Discussion | 3 | 01-12-2010 11:30 AM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
