Old 10-17-2023, 10:15 PM   #1
Bentobox85
Drives: 2012 Yaris Sedan
Passenger headlight and turn signal not working
The car is 2012 Yaris Sedan.
As stated in the title, the passenger side headlight and turn signal are not working.
If I turn on the high beams all the lights work fine so I know the headlight bulb itself is not dead. Also, when the headlights are switched on all the parking lights work, which are the same bulbs as the turn indicators so again, the bulbs are not the issue. I checked all the fuses and nothing seemed to be blown. All hazard lights, except for front passenger side work. Any help would be greatly appreciated
Bentobox85 is offline   Reply With Quote
Old 10-17-2023, 11:35 PM   #2
komichal
Well I suppose your Yaris uses H4 bulb which contains "two bulbs in one" so one of them is toasted. Broke thread should be clearly visible in the bulb. If not sure, try to swap left and right bulbs to see what happens.
Old 10-18-2023, 06:13 AM   #3
Bentobox85
There is a separate bulb for both the headlight and turn signal. Neither one is burnt out. I can drive around with my high beams on and both headlights are active. The bulb for the turn signal illuminates when I turn on the headlights but it does not flash when I indicate a right hand turn
Old 10-18-2023, 08:46 AM   #4
What komichal is saying about the H4 bulb. It is a single dual filament bulb which performs both low and high beams. The low beam filament is blown.
Replace both sides now. The driver's side will blow soon.
Old 10-18-2023, 02:47 PM   #5
komichal
"The bulb for the turn signal illuminates when I turn on the headlights"
If this really happens than you have some serious electricity problem, but I somehow doubt that it is the case... does it really happen? Sorry but this combo is quite improbable.
Headlight problem persists after new bulb RMcG DIY / Maintenance / Service 11 09-22-2024 02:57 PM
Advice needed for replacing headlight bulb RMcG DIY / Maintenance / Service 21 12-06-2022 09:59 PM
2007 Hatchback Headlights won't turn off draining battery GLMaddawg DIY / Maintenance / Service 3 08-23-2020 03:23 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
