Old 11-12-2008, 12:58 PM   #1
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Squeaky Transmission? 5MT
I have a strange occurrence where my Transmission squeaks just the slightest little bit when going into and out of gear...mostly 3rd and 4th. I originally thought it was my brakes or someone elses brakes. It doesn't happen every time though either. Can anyone tell me what is going on?
Old 11-12-2008, 02:01 PM   #2
kou
Drives: 08 lb
lube this part. if you look under the hood at your linkage move this part side to side and lube. white lithium grease in the spray can works great.
Old 11-12-2008, 03:16 PM   #3
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Thanks kou! I've learned to live with the squeak but hopefully this DIY will kill it. Any brand recommendation for a "white lithium grease in the spray can"?
aca72 is offline   Reply With Quote
Old 11-12-2008, 03:21 PM   #4
kou
Drives: 08 lb
no special brand its just easier with the can,it should come with a little red straw for the nozzle. spray in the gap between the two parts.it moves side to side when going 3-4.i changed the pic slightly so you can see where to spray exactly.
Old 11-12-2008, 03:46 PM   #5
slothman86
slothman86's Avatar
Wow, so the yellow part? and the squeak will be gone?
Old 11-12-2008, 03:48 PM   #6
kou
Drives: 08 lb
spray in the two little yellow marks inside the circle and the noise should go away.
Old 11-12-2008, 04:31 PM   #7
slothman86
slothman86's Avatar
thanks much! I appreciate it!
Old 11-12-2008, 04:35 PM   #8
kou
Drives: 08 lb
anytime.
Old 11-12-2008, 08:11 PM   #9
ruimond
Drives: Yaris YR
Haha i had this problem, i actually got it fixed this morning too by the Toyota Service Mechanic, he sprayed some stuff on that part to. Now it's gone. :D
Old 11-12-2008, 10:42 PM   #10
slothman86
slothman86's Avatar
I went ahead and bought some of the before mentioned lube from advance auto for about $3. I sprayed some on each linkage just to make sure. There is no squeak anymore. You may need to take out the air box and battery tray to be able to lube everything up...unless you are Mr. Fantastic. ^^ Great advice! I may spray this on some suspension bushings as well...
Old 11-13-2008, 01:07 AM   #11
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Thanks for the post... this has been squeaking on mine for the last couple months. F the dealership... I'll do it!
2006 Red Blitzed RS 5-door
Old 11-13-2008, 08:59 AM   #12
IllusionX
Drives: 07 Yaris Sedan Aero
haha.. mine is doing that since 2+ years ago... and is still doing it after 53000km. ^^
my personal toyota mechanic told me to take the shift linkage out and grease the hell out of it. but i got lazy and never did it. haha but thanks, i'll shoot some grease to that part see how it goes.
Old 11-13-2008, 12:11 PM   #13
TheSilkySmooth
TheSilkySmooth's Avatar
Now i see where the battery GND is!
You may wanna to try a dry moly lube so you don't collect any sand if you live in areas where the roads are sanded
Sonja's Bro
Old 11-13-2008, 12:56 PM   #14
aca72
aca72's Avatar
DIY done. Squeak is killed!
Old 11-13-2008, 05:39 PM   #15
slothman86
slothman86's Avatar
Alright! I didn't know that it was this widespread!
Old 11-17-2008, 10:14 AM   #16
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
ricepower is offline   Reply With Quote
Old 12-14-2008, 03:19 AM   #17
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
enobmort42 is offline   Reply With Quote
Old 12-14-2008, 06:04 AM   #18
ricepower
ricepower's Avatar
Thumbs up
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
