Old 12-03-2023, 11:33 AM   #1
Phatdonkey78
Drives: 2007 Hatch
New wheel bearing slop
Just replaced both front wheel bearings on my 2007 hatch.
When I pressed them in, there was some play in the bearing. Pressed in the hub and the whole thing still had play. I know these Timken bearings seem to be split down the middle. As I installed the axle nut it tightened up some. When I put the wheel back on and tightened the axle nut to 165 ft pounds and jacked the wheel back off the ground, the play was gone completely. I have since driven around the neighborhood and went and got gas and the bearings are nice and quiet.
I'm basically just making sure this is how the bearings tighten up? Is it normal for there to be some play until the axle nut is tight?
Thanks in advance.
Phatdonkey78 is offline   Reply With Quote
Wheel bearing problems Doobiejack Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-29-2024 08:59 PM
Wheel bearing wobble? BennyLava DIY / Maintenance / Service 10 05-18-2018 06:11 AM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
