Old 07-10-2025, 05:33 PM   #1
drd
Drives: Toyota Yaris
2ZR-FE Swap Exhaust Questions
I'm planning to do a 2ZR-FE in the near future, and am in the process of researching all the parts I'm going to need. One thing that I am unsure of, is what to do for the exhaust. I know custom is obviously an option, but I'd like to know what the community thinks of this.
The Scion xD shares many similarities with the 2nd gen Yaris HB, which I believe is due to them having the same sub-frame (please someone correct me if I'm wrong) - in fact, while the overall dimensions of these 2 cars differ slightly, they appear to have the exact same wheelbase of 96.9 inches according to edmunds.
Now, for the swap, it's known that the header of the 1.8L 2ZR will not match up to the Yaris downpipe/midpipe. Interestingly, it seems that the axle-back muffler portion of the xD exhaust WILL bolt right up to the stock Yaris midpipe (see: https://www.yarisworld.com/forums/sh...ad.php?t=20153 post #8). This begs the question - is the xD midpipe the same or close enough to the Yaris midpipe to fit under the car? This could be a solution to the 2ZR swap exhaust - 2ZR engine > 2ZR header > xD midpipe > Yaris/xD muffler - does that make sense?
Here are the parts, labeled Front Pipe - the part numbers are different, but they look very similar.
Yaris https://parts.olathetoyota.com/oem-p...ipe-1741021541
xD https://parts.olathetoyota.com/oem-p...ipe-1741037270
I think I would want to go with a slightly larger diameter than stock (I need to confirm the diameter of these with Magnaflow), but these also look very similar.
Yaris https://www.magnaflow.com/products/5...ytic-converter
xD https://www.magnaflow.com/products/5...ytic-converter
Will it fit? The design and turns of the pipes look they would fit very similarly under the car. I guess worst case scenario I could try the xD Magnaflow out, and if it doesn't fit return it and go custom. Thoughts YW?
Thanks!
drd is offline   Reply With Quote
slightly off engine swap questions xb vs yaris sh0rtlife Performance Modifications 12 02-04-2023 07:21 PM
Information for 2zr fe engine swap in my 2012 ncp131 Yaris 20yaris12 Third Gen Yaris General Discussion 0 07-02-2016 11:54 PM
My 2zrfe swap brushforhire Performance Modifications 131 06-08-2016 09:43 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
TRD Exhaust and TRD Header questions Liquidus Ocelot Performance Modifications 8 02-23-2014 02:58 PM
