Old 08-20-2025, 12:05 PM   #1
matthewdoe782
Drives: 2008 Yaris S Sedan
Antenna adapter for 2008 Yaris S sedan
I'm installing a new head unit and need an adapter for the antenna.
matthewdoe782 is offline   Reply With Quote
Old 08-28-2025, 03:55 AM   #2
satelitus
Drives: Toyota Yaris
For installing a new head unit in a 2008 Yaris S sedan, you’ll need a Toyota-to-DIN antenna adapter to connect the car’s antenna plug to your aftermarket stereo. This adapter typically has a rectangular Toyota connector on one end and a standard round DIN plug on the other, built for easy connection without cutting the original wiring.
Most of these adapters come with a blue power lead, which should be wired to your new head unit’s “antenna” or “remote” output. This ensures the factory antenna amplifier is powered up properly when the stereo is on, resulting in optimal radio reception.
Dynamic Sounds, AliExpress, and other retailers carry Toyota-specific aerial adapters compatible with 2008 Yaris models, sometimes bundled with wiring kits. It’s worth confirming the connector matches your factory plug before ordering, but this is a common accessory when swapping head units in Toyotas of this generation.
_________________________
alkomat online
satelitus is offline   Reply With Quote
Toyota ending Yaris Hatch & Sedan production for United States by end of June ferio252 Third Gen Yaris General Discussion 18 07-13-2020 02:05 PM
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 02:50 AM
Yaris or Yaris S sedan? glockprime New YARIS Purchase Forum 2 09-12-2006 10:32 AM
