Old 11-14-2006, 07:36 PM   #1
For Sale: "Thai style" LED standard Tail Light Assembly
Having changed my lights to the JDM RS-style ones, I have my old taillights lying around, so this might be interesting for anyone who wants a slightly different look!
These taillights are STOCK on all Yarii here in Thailand. They can also be considered JDM, as the non-RS Vitz in Japan uses these too.
They are very similar to the taillights available in the US/Canada, but with the difference of having integrated LEDs for the brake lights:
There is also one fog lamp in the right side assembly (where the reverse lamp is on the other side)
I must also warn you that the original connectors were cut off for the installation of my new lights, so you will need to do some splicing/soldering. As far as I can tell the wiring is the same with the stock US lights, I have managed to take a couple of quick pics before the connector was cut:
(edit: managed to find a pic after the cutting, which shows the wires better:)
I would be asking for US$125 (new price) for the pair INCLUDING shipping by EMS (can be tracked online and should take less than a week to arrive).
It is possible that your country's customs may want to charge some import duty on these, so if you wish, I could undervalue them and declare them as replacements, which should keep things reasonable.
So, anyone interested? Feel free to ask questions!
eTiMaGo is offline
Old 11-15-2006, 06:59 AM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
That's not a bad looking light.
I already have the nicest tails in the world but those would make a pretty unique car in North America.
That connector (even if you hadn't cut it off) is completely different than factory here though. Ours are built into the housing.
It might help a potential purchaser if you were to get a good photo of that connector.
You might also put "Thai Style" or something like that in your thread title.
Good luck!
Violin is offline
Old 11-15-2006, 07:52 AM   #3
Thanks for the input Violin, I'll try to find the assignments of the cables so that it would be easy to match them to the car's wiring.
eTiMaGo is offline
Old 11-15-2006, 08:02 AM   #4
riceboy
Drives: icebox
I like the tails too... hell at least it'd be something different...
riceboy is offline
Old 11-16-2006, 06:03 AM   #5
Violin
Violin's Avatar
Probably the easiest way to rewire those would be to go to Radio Shack and get two pairs of six pin male and female molex connectors, cut the body side off the USDM harness, crimp new connectors on each side and be done with it.
Violin is offline
Old 11-16-2006, 07:18 PM   #6
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Cant see the pics..
Chris07LB is offline
Old 11-16-2006, 08:33 PM   #7
argh looks like I put a bit too much load on my free hosting :p
eTiMaGo is offline
Old 11-17-2006, 03:57 AM   #8
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
Hmmm... these are interesting, I wish I had the 200 spare to pony up, I'd like to take a look at those LED modules... maybe be able to make a repeatable retrofit for USDM tails with that type of LED module.
paultyler_82 is offline
Old 11-17-2006, 08:31 AM   #9
Chris07LB
Chris07LB's Avatar
Did you ever get my FedEx package from weeks ago??
Old 11-22-2006, 09:00 PM   #10
paultyler_82
Ack, yeah, sorry, I got it, and thank you! those were a lot better than the stock hardware, it was still a PITA installing that thing though.
Old 12-07-2006, 03:59 AM   #11
paultyler_82
eTimago, just curious, how do you turn the rear fog light on and off? Do you have a separate switch or is it tied to the front fog lights?
Old 12-18-2006, 10:24 PM   #12
Black Yaris
der Zeck
Black Yaris's Avatar
I just reallized there is another red bulb just below the LED's what is that for?
Black Yaris is offline
Old 12-18-2006, 10:27 PM   #13
bigsky2
Cousin Vitz
bigsky2's Avatar
I think that's the rear fog light?
etimago correct me if I'm wrong
bigsky2 is offline
Old 12-18-2006, 10:29 PM   #14
Black Yaris
der Zeck
The one below the turn signal is the fog, I think the LED is only a break lamp and the bulb just below the LED is the marker/running lamps
Old 12-18-2006, 10:35 PM   #15
You might want to look at the second picture, and I'll guide you through it
The top LEDs are for the brakes.
There is also a bulb in the inverted L section which is the normal night lights. Then the inner section has the orange turn lights at the top (white section), and depending on the side, either a fog light (right) or the reverse light (left)
As for the fog lights control, there is a ring on the steering wheel control stalk, but if needed you should be able to wire up a switch to the panel under the hand brake.
eTiMaGo is offline
Old 12-18-2006, 10:37 PM   #16
Black Yaris
der Zeck
Hmm.... still thinkin about your tail lamps or lowing springs.... wich will my wife be LESS pissed at me spending money one things I don't NEED
Old 12-18-2006, 10:58 PM   #17
still very much available
eTiMaGo is offline
Old 12-18-2006, 11:00 PM   #18
Black Yaris
der Zeck
100 bux more and I can go JDM though... and 45 less and I can go with tanube springs..... this is a hard one
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
blinking LED light kaymm In Car Entertainment + Electronics (audio / video / alarm) 3 09-14-2006 10:05 PM
